Thread: Steering column
View Single Post
hobbyshark hobbyshark is offline
Got the bearing and now see that an epic bearing fail occurred the outer ring on the bearing gave out, allowing the inner race that contains the ball bearings to slide down in the column. I gotta somehow pull that inner bearing assembly back up the column shaft. I think I need to make a Gieco commercial showing a guy with a partially disassembled 928 cursing a blue streak. "When you're a 928 owner you curse...a lot. It's what 928 owners do"
Old 10-18-2015, 08:43 PM
