+1. Eliminate the cam/valve /timing issue and see if you still have a problem. if you need to, pull the rockers (hopefully you can do that without disturbing too much). Then if need be, put them back row by row - ie 1/4, check rotation etc.
A long route, but sure to identify source of problem. Good luck.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
