youfamissim's Avatar
87 930, 35k, <1K Miles per year. Blue smoke
Need advice on an oil burning issue. Car is low miles, driven infrequently - sits for months. Blue smoke persists after warm up. Performance is otherwise superior. Pls advise on causes.
Old 07-02-2018, 09:29 AM
Thanks in advance
CPT KAOS
LeftCoastErik's Avatar
turbo seals or valve seals
Erik- RGruppe #743
Sports Purpose Garage
CPTKAOS 313HP/265TQ(wheels)2150#
Old 07-02-2018, 11:23 AM
kevinbodman930's Avatar
Yepp sounds like valve guides,but i am no expert.You might want to call Chris at Turbo/Kraft.
Old 07-02-2018, 06:10 PM
Bucketlist's Avatar
Check your oil level on the stick warm and running, you don't want it overfull when warm. I started filling mine right about to the add mark(cold) because of a similar experience. There is plenty of oil in the tank.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 07-03-2018, 04:05 AM
Is it possible to change the valve seals with the engine in the car, or just better to pull it?
Old 07-03-2018, 04:20 AM
T77911S's Avatar
check oil level first.
DRIVE IT!!!!
put some miles on it and see how it is.
valve guide seals usually smoke when you let off the gas. the closed throttle plate causes the engine to suck oil in past the seals.
valve guides don't go bad sitting.
you could have some oil getting past the rings. again, drive it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-03-2018, 04:46 AM
Alan L's Avatar
May even be oil accumulated in exhaust system. A good long run would/should clear that. As T77911S says, then see if it trails smoke on trailing throttle. It should give a burst of smoke when back on the gas, if guide seals.
If you had to replace, MUUUCH easier with engine out. I doubt you would save any time by not pulling the engine. May well take a lot longer with engine in.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 07-03-2018, 05:42 PM
My thoughts are the same as T77: drive it hard, aka italian tune-up....having first confirmed basic engine health (compression test, new,spark plugs are inexpensive), ignition function, that oil isn't gasoline-saturated, etc. John
Old 07-03-2018, 08:38 PM
