Red face Test fuel head/distributor in la area?
Anyone in the LA area have a rig to test fuel distributor flow etc? (And know how to tweak it)? It's a 145 unit (3.6T)
I have mine out from a cleaning of overfill of oil and I'm worried I damaged an o-ring or something inside by cleaning it with carb cleaner. The membrane material and the o-rings on the regulator are fine though - so I'm thinking maybe it's some tweaking issue causing cylinder 5 to flood/no fire
73 911s Targa / 94 964 Turbo 3.6 / 77 Guzzi Le Mans / 93 Guzzi 1000s / 73 Guzzi V7sport / 77 Yamaha DT400 / 06 Ducati Paul Smart / 15 MBZ G550 / 01 Range Rover 4.6
Old 11-07-2018, 09:28 PM
T77911S's Avatar
you can check for even flow out of all 6 ports.
I tested mine at 3 points of operation. one simulated idle, one simulated mid RPM cruise and the 3rd of course was WOT.
the idle test took a long time, around 15 minutes at least. I put a battery charger on the batt for all the tests.
you also want to make sure you don't have any that leak
you can also buy the rebuild kit for about $100.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 11-08-2018, 03:50 AM
Crotchety Old Bastard
RarlyL8's Avatar
Cleanup from the overfill probably didn't hurt anything. The -145 fuel distributors are less solvent sensitive than the earlier Euro -037 units. Before doing anything to your FD change all of your spark plugs. The oil overfill likely has fouled at least one of them. If that doesn't do the trick we can look closer at the fuel system.
Old 11-08-2018, 06:35 AM
Looks like the Salvox CIS fuel head rebuild kit is still around $70 shipped on ebay. The one in this link may or may not be the correct one for yours but there are more of them on the Salvox.com site and ebay.
https://www.ebay.com/itm/Bosch-Fuel-Distributor-Rebuild-Kit-for-PORSCHE-911-3-3-Turbo-0438100145/301844846729?hash=item46475ad889:g:LjMAAOSwZjJU6Jm n:rk:4f:0
Repair kits for Aluminum Bosch fuel distributors - salvox
Rebuild instructions ---CLICK HERE FOR FULL INSTRUCTIONS --- - salvox
Old 11-08-2018, 06:47 AM
T77911S's Avatar
he thinks he damaged it with crab cleaner, not oil.
RACE CAR:: sold
Old 11-08-2018, 09:48 AM
dirty crabs.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 11-08-2018, 10:38 AM
RarlyL8's Avatar
The no fire on cyl 5 is more likely caused from the oil overfill instead of the attempt to clean the FD with solvents.
Old 11-08-2018, 10:48 AM
Originally Posted by slyguy View Post
dirty crabs.
ooooo I love a dirty crab!
Old 11-08-2018, 01:13 PM
Hah maybe a bug got in, who knows. I have the FD on bench and all cleaned up (parts will all go back in EXACLTY where they came from sans the little pipe filters those are staying out, and the diaphragm is really nasty/crinkled, could have been damaged from crab cleaner. Have kit arriving to replace all and see if that is the problem.
Bloody fuel pressure kit I got from HF has no connection for the fuel >WUR line (13mm male - the one it came with has a giant hole in the side of it what use is that). Grrr. Need to check pressures first once FD back on.
Old 11-08-2018, 01:48 PM
Your funky wrinkled original rubber diaphragm got that way from the ethanol in todays E10 Gas. The original rubber o-rings and diaphragm in aluminum CIS fuel heads are not ethanol tolerant.
The rubber parts in Salvox rebuild kits are ethanol tolerant so E10 gas is OK in them. Maybe you could run E85 in a CIS fuel head with Salvox rubber parts installed if you could modify it to inject wayyy more fuel correctly.
Old 11-08-2018, 04:37 PM
T77911S's Avatar
dirty crabs.
you get from dirty grils (girls)...
RACE CAR:: sold
Old 11-09-2018, 03:58 AM
T77911S's Avatar
my brother has 140k on his alum, head and it runs great.
I wonder if it is more damaging when cars sit.
RACE CAR:: sold
Old 11-09-2018, 03:59 AM
Alan L's Avatar
I'm more interested in the dirty grils and crab cleaner. Where do you get this stuff? ebay? I don't see it listed on pelican.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-09-2018, 11:58 PM
Thank You Fair-man for the FM rebuild kit ebay heads up. I'll buy anything w/free shipping. Will put it on the mtn -o-parts for use in about a year when I retire and get at it.
Gary
Old 11-11-2018, 10:24 PM
