fuel accumulator
Does it matter which way around the TOP fuel lines go on the fuel accumulator?
You have a center and offset fitting and 2 lines. I wouldn't have thought it would make a difference, but wondering - trying to find source of an issue. And the last thing I did was install a new accumulator. Thanks Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I think I can answer my Q. It does matter - according to one CIS manual I checked. The other manual I have shows no difference. I think I need to swap the lines.
Alan
Installed mine this weekend.
Don’t know if it matters which way it is plumbed but I put it on the way it came off.That was with the offset fitting for the fuel in and the centered to the filter. I have to say I was shocked to see the colour of the fuel that came from the old filter |
I'm thinking it does matter. One diagram I have just shows a fuel flow in/out thru the ports.
Another diagram in another manual shows internal reed valves. In which case it probably matters. Regards Alan
Crotchety Old Bastard
There are a few different accumulators over the years but they all seem to work the same way, one in, one out, bottom overflow/return. The lines cannot be mixed up.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Hi Brian, well, I did manage to mix them up. Bit tight in there and somehow I followed the wrong line to the wrong place. Anyhow, swapped over now. Idling fine - just have to take it for a run.
Regards Alan
