Euro 930 Engine and Tranny serial no. mismatch
Hi, folks.
I'm trying to figure out engine/tranny serial number logic on my '84 930, and/or the possibility of whether the engine has been swapped out. I have no paperwork evidence that it has been swapped, only a serial number inconsistency. The option sticker and Redbook (based on delivery date) say that the car should have "E" Program serial numbers on both the engine (67E) and tranny (77E). The tranny number starts with 77E and matches the COA, but the engine number does not and has a 67F serial number, which the Redbook says they didn't start using until a few months later. Has anyone else seen this mismatch? Perhaps they started using the 67Fs before the Redbook says they did... and the COA is incorrect... or the motor was swapped out for a slightly later one at some point. TIA
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
I’ve never checked the numbers on my 81 but I’m pretty certain they’re both original to the car.
I post my numbers if you think it’ll be helpful.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
Thx. Redbook doesn't show much on the tranny numbers for prior to 84, but engine serial should start with 671 or 67C.
gearhead
The Redbook has many errors, but this isn't one of them. I would trust the COA on this. You've got a later engine in your car.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
My 84 930 has 67E engine # and 77E trans #
Helpful info. Thanks!
Thanks again for the info.
I spoke to the original owner and he did, in fact, have the motor swapped out back in 1986. It threw a rod due to overboost, so they ordered a new one from Porsche ($13K) and swapped it out. The timing jives with the serial number. Interesting that he didn't have to pay for it. He said insurance covered it (not sure if he meant warranty).
