Brando
They’re all factory 915 up to 87’. The solution is 930 or g50
Turbo powa! 1977 911s. it's cool |
I just pulled my motor/915 transmission out to stuff a 930 gearbox in it. I broke something in 3rd at the track this past August. My boost wasn't even at full (~360whp). Most of the 915 transmissions are 40 years old, and without a rebuild plus the added stress of a turbo it won't take long to break. I turboed mine in October of 2015. So it did last awhile. But like Ronnie said, I was one of those dainty drivers with the 915.
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
Mighty Meatlocker Turbo
Just to add a little mumbojumbo to what Brandon and Kyle said above, the input shaft of the later 930 boxes also has to be modified, but while adding some expense, and general hassle (as Kyle mentioned), the mods are a straightforward procedure (no experimental voodoo involved ) that certain shops can do.Also, the Wevo parts help minimize flex and stress by keeping the components aligned, but of course, does not address the skinny gears themselves. So if a 915 is to be used, then engine torque should really be limited to well under 300 ft lbs by keeping boost pressure low. But that said, even with a torque bump to say, 250-270 ft lbs at about 5psi boost, that is enough of an increase in acceleration force to have someone accustomed to the torque of a n/a 3.2, etc., going "Ohhhhh shiiiiiiitttttt" for a while! ![]() Quote:
A little off-topic here, but why Porsche used CIS on the Turbo model when they already had EFI (and a very good EFI at its time)?, The Motronic system is far more advanced and has a much better control and precision for both the fuel and spark for any turbo setup.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Brando
Hard for me to say. I guess money for design when it was still working pretty good? When the 964 turbo cis ended in 92’ or whatever it was still the fast car. Not just for Porsche. It was still the benchmark for speed.
). Todd knows the Motronic system very well.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Instagram:@blacklistracer
Happy New Year everyone!
To chime in, Todd at Protomotive still supplies the chip required for the 3.2 Carrera Turbo conversion. You can also get their Dual Rate Fuel Pressure Regulator if desired. I have recently completed my 3.2 Carrera conversion to turbo although I am currently improving upon the piping system and tracking a boost leak. I intend to write a post about my project some time in the future. It is worth mentioning that my car is a Euro 3.2 Carrera with 10.3:1 Compression Ratio!
Bolt-on Turbocharged 1987 911 3.2 Carrera G50 - Stock Engine (10.3:1 P&Cs), GT3582R Turbo at 0.5bar, Protomotive Intercooler, Protomotive Headers, Protomotive Fuel Pressure Regulator, Titanium Exhaust & Resonator, Titanium TiAL F46 WG Pipe, Titanium Air Filter Plumbing, RUF Speedlines, RUF Strut Brace, RUF Steering Wheel, KEP Turbo Clutch, Koni Adjustable Shocks, 23/29mm TBs, WEVO G50 Shifter, 996 Turbo Brakes. |
