Thanks for the help, I appreciate the input. I’ve been hanging around here in the shadows for the better part of 20 years, usually a quick search sets me straight, I knew we would get it sorted. |
Glad you found the culprit. I once unplugged my freq valve just for kicks to see if a person could tune around it. Not happening, as you've found out, runs wayyyy too lean.
My reason for trying this was to answer a what-if equation.....what if that freq valve should ever die? Finding a replacement might become a challenge. |
Easy fixes are a wonderful thing.
Frequency valves / injectors are a fairly simple device but they do age or degrade with time like everything else. Should the valve itself die I would take that opportunity to rid myself of it and install a -037 Euro fuel distributor or have your -145 USA unit modified to delete the Lambda system and add more head room for mods. ;) |
I had the same issue with my 91 turbo, except my relay is under the passenger seat!
I wish I would have come across this post earlier as it took me a few weeks of diagnosis and $700 in "tune up" up parts before I figured out the relay was bad. The entertaining part of my fun was I had a relay (which are a little spendy) in a spare parts pile the whole time. Quote:
| All times are GMT -8. The time now is 12:27 AM. |
