Brando
quattrorunner's Avatar
oil drain plug as return for turbo
Is there a fitting that would allow this? I have an 84 block. Thanks....
Turbo powa!
1977 911s. it's cool
Old 07-31-2017, 12:59 PM
Chain fence eating turbo
I drilled a hole through a brand new plug and then welded a steel AN fitting on with a barb.
Old 07-31-2017, 03:26 PM
Brando
hey now! Simple, Thanks.
Turbo powa!
Old 07-31-2017, 05:18 PM
Worded funky. Drilled hole the same size as the Push Lok AN style cone male fitting. Then, I stuck a drill bit the size of the hole to ensure perfect alignment followed by MIG welding. Then I simply used a Push Lok 90° swivel fitting with a barb to the hose with a hose clamp over the hose and barb.
Old 07-31-2017, 08:30 PM
Brando
I think I understood it better the first time.
Turbo powa!
Old 07-31-2017, 10:44 PM
Turbofrog
smurfbus's Avatar
But does it leave enough ground clearance? I've thought about doing that too but was too scared to risk hitting something with it and tearing the oil pan.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-01-2017, 12:21 AM
I bought a cheap oil drain plug from AutoZone or other FLAPS to weld a 45* cone male fitting to.
I drilled an internal hole the size of this male fitting below into the oil drain plug above while holding in place during the weld with a drill bit the size of the hole. I lopped off some of the pipe threads on the male fitting below so it wouldn't stick out too far, but not too much to allow enough material to weld to and use a wrench on the male fitting flats. The flats of the oil drain plug were sacrificed during welding.
Lastly, I used this barb from Push-Lok (hydraulic fitting company) that has a barb I run Push-Lok hose from that mates to the turbo oil drain fitting I also have a barb on secured with hose clamps.
All parts are steel so I could weld to them.
Since the swivel 90* gets so close to one of the header primaries, I had to wrap the primary with header wrap in about a 3" wide section to keep the radiant heat away.
Works fine.
To drain the oil, I have to loosen and remove the 90, drain the oil from the turbo hose (not much from the hose), but the sump holds a lot (obviously).
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-01-2017, 07:22 AM
Tippy, can you post a pic, or did you already? I'm texting and driving, so can't check.
Old 08-01-2017, 07:34 AM
Pics attached right above your post.
Old 08-01-2017, 07:38 AM
It's never concerned me.
There is the main oil hose from the oil tank to is low too.
Old 08-01-2017, 07:40 AM
scottrx7tt's Avatar
Heres what i did. Obviously, mine is a 3.0 with the sump plate, but you should be able to use it for your application also.
It is a banjo oil fitting from Setrab
Old 08-01-2017, 09:04 AM
Brando
my drain plug is easier to clear the road luckily.
Turbo powa!
Old 08-01-2017, 10:15 AM
Turbofrog
smurfbus's Avatar
No worries on the side drain plug. I have the sump plate on mine. That banjo does not make it much lower though.
Old 08-01-2017, 11:28 AM
Brando
The banjo is slick.
Turbo powa!
Old 08-01-2017, 11:34 AM
T77911S's Avatar
i think jfairman has done this or he routed it to dump into the breather on the triangle of death.
if you ran it to the drain plug would you still need the turbo oil pump?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-01-2017, 11:58 AM
912-6 Turbo
I used a -10AN to M18.5 x 1.5 fitting from Jegs and connected that to a -10AN 90 degree swivel with braided hose which connects to the drain fitting on my GT3076R turbo on my 3.2.
This is the best pic I could find
No leaks and no issues ... been using this setup for the last 3 years. No scavenge pump required. To drain the oil, I just loosen the 90 degree swivel and let it drain in to a big bucket.
1966 912 Turbo - Carrera 3.2L - GT3076R - Bosch 044 - Intercooled - 55lb injectors - 0.5 Bar - Tial F46 - Magnesium 915 7:31 - BBS E26 15x9, 15x10 - Link G4X Fury
Old 08-01-2017, 12:27 PM
912-6 Turbo
The other end ....
The pipe looks close to the turbo flange coming off the turbo drain but I can get 2 fingers in there so enough room for heat dissipation I would think.
Old 08-01-2017, 12:36 PM
scottrx7tt's Avatar
The banjo is slick.
My car is gravity drain into the sump. I've never had a problem with gravity being able to keep up. No smoke underboost. No smoke at startup
Old 08-01-2017, 12:46 PM
Brando
The run into the chain boxes or oil plug don't require a pump but the line into the triangle of death area or the tank requires a pump.
Turbo powa!
Old 08-01-2017, 01:50 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Originally Posted by IROC 912 View Post
The pipe looks close . . . but I can get 2 fingers in there so enough room . . .
Old 08-01-2017, 04:27 PM
