Alan L's Avatar
I was in the passenger seat during a dyno run. The engine was screaming at 6000. I got out and stood at the back. Terrifying - since I built it.
You don't hear that stuff on the track while driving it. It scared me to death and I was so glad when it was over and my engine still was in one piece.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-12-2022, 12:44 AM
Originally Posted by gassian View Post
any update with dyno run?
Finally made it to a dyno today. Car is still mostly stock other than Classic Retrofit CDI+, a test pipe in place of the cat, and of course the Raptor-X modification to my 3DLZ by Evergreen Turbo. 282 max whp @5600rpm and 297 max torque at 4300rpm.
Old 01-03-2025, 06:49 PM
Thanks for closing the loop here. Dyno’s are hard to compare against anything other than themselves on the same day. More importantly, how does it drive? What boost spring are you running?
I am running a mid-1990s 7006 that was the hotness back then… I’m waiting for it to die so I can get one of these Raptor upgrades, but it just keeps soldiering on.
Ken
1986 930 2016 R1200RS
Old 01-04-2025, 05:35 AM
It drives great, strong linear pull from just over 3000rpm on up and rarely feels like I’m in between gears. I have not done anything with the boost spring, still factory.
Old 01-04-2025, 05:42 AM
Banned
Agreed, cool of you to circle back here and provide update years later on the upgrade.
Seems quite healthy, but begs the obvious question: which type dyno?
Consider an intercooler (at the least) and headers (if within budget / ability) to round out a REALLY usable / tangible set of upgrades to make it a suuuuper great driver. You're welcome
Old 01-04-2025, 08:53 AM
This was a Dynojet. I want to keep it as close to stock as possible so I don’t think I’ll do anything else until it needs a rebuild, at which point I may put in SC cams.
Old 01-04-2025, 09:04 AM
