Topocalma
Reverse 'lost' - do I need to pull the transmission - how to best diagnose
The Turbo (77) seems to know that I like repairing it - just when I am done with the suspension rebuild it throws the following at me:
The reverse gear went from working without any issues to 'non existance'. This is the 930 4-speed gearbox. I researched on here and it seems that this issue does not occur to often, that the most probable cause is shift coupler alignment, and that people sometimes fix it by overhauling their transmission or just reajusting clutch and shift coupler.
My diagnosis so far suggests the following:
- Reverse feels completely 'blocked' and there was no gradual deterioration
- All other gears work absolutely fine and unchanged (suggesting it rather is not a clutch issue?)
- When disconnecting the shift coupler and operating the shift rod by hand I am able to easily get into 1/2 and 3/4 but I do not seem to be able to turn the shift rod from the 1/2 position in neutral (clutch depressed) to get into the reverse 'angle' of the shifter. I hear a metallic 'clang' on both sides when moving the shift coupler in neutral from side to side. To say it differently, it feels to me that the issue is not that I cannot push the rod back into the gearbox for reverse once the angle is correct but rather that I can't even change the angle to get to the reverse 'angle' in neutral.
I created a little video showing what I mean...
The big question now is what should I do / test before resorting to pulling the transmission.
The only upside of pulling the transmission would be a possible overhaul of it - the second gear bearing(s) are extremely loud which is quite annoying. In second rather than the motor and turbo I mostly hear the bearing :-)
1973 2.4T gemini blue
1977 3.0 Turbo slate grey
1973 2.4s motor rebuilding project
Old 11-17-2019, 03:55 AM
Brando
quattrorunner's Avatar
That does seem ominous. From there I’d say you have a blockage keeping the shift selector from moving freely but that would seem to be a blockage inside.
Turbo powa!
1977 911s. it's cool
Old 11-17-2019, 06:37 AM
Topo,
You could start buy draining the transmission gear oil. Then remove the Selector Cover With Fork. You can look inside to see if the Reverse Rod is engaged correctly and/or if there is any obstruction like possibly the reverse light switch pin or ???
Best of luck,
Rahl
Old 11-17-2019, 11:00 AM
Topo,
You can also do a search to find related threads.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1001651-930-transmission-rebuild-early-1977-box.html?highlight=transmission+rebuild
See if this one helps. It is a rebuild thread but may give you a better idea of what is going on inside your transmission.
Rahl
Old 11-17-2019, 11:04 AM
I lost reverse in my 1986 930 today with very similar symptoms... did you find a resolution?
Old 02-19-2022, 05:45 PM
crb07's Avatar
Check shift rod bushing first, under the hump in the floor behind seats. Mine was bad but did not feel sloppy, but car would not go into reverse, kept going into first gear.
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 02-21-2022, 05:12 AM
It's a 914 ...
stownsen914's Avatar
I'd be looking at the linkage first. Make sure everything is moving as expected.
Old 02-21-2022, 09:40 AM
Alan L's Avatar
There is a critical bush below the shift lever. I just replaced mine - it was totally mashed. I still had gears, but the shifting was getting fairly random.
It is a bit of work to get in there, just to have a look. But way less work than pulling a gbox apart , to find it was a shift bush.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-21-2022, 10:06 AM
mark houghton's Avatar
Lost reverse in mine once. For me it was simply the allen headed locating pin that centers the shift coupler with the shift rod under the access plate between the seats. It was loose, allowing slop. For you, wouldn't it be nice if so simple but from your description it sounds like something else is amiss.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-22-2022, 05:42 AM
Alan L's Avatar
+1 above. First place to look. In the tunnel housing - tapered allen screw. Can be quite troublesome. If not Tight Tight, fix. Usually needs some loctite.
I suspect if that is affecting reverse, then other gears would fail too. But def first place to look.
Alan
Old 02-22-2022, 08:45 PM
Non User
infraredcalvin's Avatar
Stumbled upon this… I thought I remembered that reverse gears are 1st thing under the cover…
https://forums.pelicanparts.com/porsche-911-technical-forum/945596-930-turbo-no-reverse-gear-possiable-explanations-internal-transmission.html
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 02-25-2022, 05:07 PM
Alan L's Avatar
Yep - not uncommon.
But try the other options first. At least , either way, not a complete g/box teardown.
Alan
Old 02-27-2022, 11:17 PM
Thank you to everyone that responded. I pulled the inspection cover today and allen screw was tight, but looks like the bushing shattered and there is lots of slop and side to side movement. I'll replace this bushing and maybe also have a look at the bushing under the shifter and replace it too.
Old 03-05-2022, 02:48 PM
Bucketlist's Avatar
If you replace the bushing under the shifter post a picture or two. This has been on my to-do list for a while. I have the part so all I need is the motivation.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 03-06-2022, 03:23 AM
The replacement shift coupler arrived from Pelican today and only took about 20 minutes to swap and the seems to have fixed reverse!
I purchased the entire shift coupler and also an extra set of bushings for the shift coupler. Replacing the bushings in the original coupler was also straight-forward and only took 20-30 minutes so now I have a spare coupler with new bushings.
I also ordered the ball cup bushing and the shift rod bushing which both go up at the shifter. Looks like the carpet needs to come out (which might mean taking the seats out?) so will save this for another day.
Online posts talk about removing the shift knob for this process, but I was able to remove the console with the shift knob in place, so looks like it might not need to come off.
Old 03-08-2022, 02:50 PM
Alan L's Avatar
I had to remove the knob but you may have got lucky.
I took the seat out . It will be a much harder job if you leave it in.
There are some screws hiding down low on both sides holding the console piece in.
Alan
Old 03-08-2022, 03:12 PM
Tags
reverse gear , transmission 930
