Remind me, how does CIS deal with accel enrichment?
Remind me
What's the CIS equivalent of an accelerator pump on a carburetor? How does CIS do acceleration enrichment? Is there an equivalent leaning on "tip out"? Thanks
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
each motor has a specific regulator with a temperature / pressure curve designed for that specific motor .. They now rebuild them and make them adjustable . so you can set the Wur off of your Air fuel ratio (AFR) not sure how carbureted cars do it , but i would be interested to see. Hope this helps Thanks Last edited by gorskined; 12-18-2023 at 11:49 AM.. |
From what I know about CIS it does not have anything, not like a carb where when you move the pedal it squirts fuel. Carbs rely on vacuum to bring fuel in from the float bowl where CIS has fuel pressure and reacts to how much air is moving past the air flow sensor plate.
I should say not all carburetors use accelerator pumps SU carbs and most motorcycle similar to SU don't.
87 930, Last edited by 908/930; 12-18-2023 at 12:34 PM.. |
I'm talking about acceleration enrichment, adding additional fuel on "tip in"
The only metering of fuel is via the airplate flap - which is mechanically connected to the metering piston in the FD. There is a cut out waist in the piston and it rises in the FD head as the airplate opens - it gets pushed up against the WUR pressure settings. As it moves up it travels past metering slits in the FD body and the exposed slits allow more fuel thru. Each slit is connected to an injector port.
The only other 'enrichment' dump is when you hit the boost mark. The WUR has an extra port which allows the manifold pressure to connect to the WUR. The pressure depresses the diaphragm in the WUR and softens the WUR pressure. This allows the piston to open more of the metering slits - so you get a boost dump enrichment. It stays in this richer WUR setting until you return to vac MAP. It doesn't take full boost for the fuel dump to occur - typically the WUR pressure starts to drop around 0.3 bar MAP. Regards Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) Last edited by Alan L; 12-18-2023 at 04:47 PM.. |
There’s an enrichment relay on the 86-89 930 under the drivers seat next to the k-jetronic box. It looks like it adjusts the frequency valve based on the described in link below.
https://cis911primer.com/pages/descr_lambda.html
'86 Porsche 930 '04 Bmw M3 '65 Ford Mustang |
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
For some reason I was thinking there was enrichment for rapid MAP changes, but the article clearly states its for temp and in fact once I re-read that I remembered. Thanks A couple of the other posts describe the normal mixture changes based on metered airflow and boost, but don't address acceleration enrichment. Looks like the K-jet doesn't really do anything for acceleration enrichment.
Are you trying to speed up throttle response? I do not think it is really possible with the stock 930 setup. EFI and individual throttle bodies should do it.
87 930, |
There is no system like on some carbs with pump jets operating on throttle linkage etc.
Basically it is all a retrospective/reactive system to what goes past the airplate. And then you wait for the turbo lag to disappear........ Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
The K Jet doesn't have an enrichment device other than described above.
However, I believe Andial had an add-on device - which fitted between the FD and WUR. There was one on my car when purchased. The only way I can see how it worked was to perhaps drop the WUR pressure even further than the dump from the WUR. Others may have some more info. Alan
umop apisdn
The air plate handles it, by flow response with a bit of overswing.
Mine is setup to log the air plate position. Yellow trace in the third panel ![]() CARB/EFI tip-in is needed because the throttle opens before fuel can react. SU/Stromberg carbs and CIS etc. all restrict unmetered air from getting in in the first place, and have the inertia of the metering device to assist with temporary enrichment. When i was a wee lad, the triple Strombergs on my first car were a pain to keep in tune but heavens they worked well.
Steve 1981 928S 4.7 ROW with KE3-Jetronic "Be the man your dog thinks you are." www.FrankenCIS.com |
Then the thing on my car was a bit different. A bell shaped thing with what looked like an adjustable spring in the bottom and two ports for the FD/WUR fuel line. It has Bosch part # I could dig up some time.
Alan
No I somehow lost my tune on my FrankenCIS or reverted back to a prior tune or something. Not sure what happened, but now need to correct somethings.
That sucks, do you have your last system and control pressures marked down?
87 930, Last edited by 908/930; 12-20-2023 at 10:07 AM.. |
Not starting from scratch, and I s/b able to get it dialed back in quickly, but its annoying. Trying to focus on selling my boat lol
