Originally Posted by 908/930 View Post
Are you trying to speed up throttle response? I do not think it is really possible with the stock 930 setup. EFI and individual throttle bodies should do it.
It should be possible or with FrankenCIS though which is why I’m exploring it. It didn’t want to “double up”
Based on my logs so far though, I don’t think it needs it. However I’m having some pressure issues rn due to a possibly bad sensor which I am replacing
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 12-24-2023, 07:01 AM
PCA Member since 1988
The others have mentioned several enrichment methods. The CIS does not have the equivalent of an acceleration pump like a carb, becuase it does not need one. With carbs, if you are at relatively low RPM and you stomp on the throttle, the air velocity through the carb decreases until RPM goes up, and mixture goes lean. The accelerator pump provides extra fuel for this transition. But CIS doesn't do that because it constantly measures airflow and adjusts mixture to the airflow and manifold vacuum.
The warmup regulator (more properly called a Control Pressure Regulator, CPR, because it regulates mixture a wide throttle settings) provides enrichment for acceleration, but it's enrichment according to airflow and manifold vacuum, not a "squirt" like an accel pump.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-30-2023, 10:38 PM
