Alan L's Avatar
cam chain tensioner
So I am having a rubbish time reasembling the engine.
I have done this job dozens of times, no issue. This time I flicked the cam chain tensioner out and managed to catch it by the little bleed valve on the top. :-(
So the part # on the unit is 930 105 547 4R. The 4s are not quite distinct - but thats what they look like.
It is a pressure fed tensioner. But the ones I bring up on Pelican do not look pressure fed?https://www.pelicanparts.com/catalog/SuperCat/0751/POR_0751_ENGCAM_pg3_timing-chain-tensioners.htm
Where would I find the equivalent tensioner.?
There is a chance I could fix this one but would rather get a new unit if possible.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-03-2024, 03:20 PM
Hi Alan, my search came up with these. Different part number but probably will work.
https://www.pelicanparts.com/search/?q=pressure+fed+timing+chain+tensioner
Best of luck,
Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her!
Old 02-03-2024, 04:04 PM
Alan L's Avatar
Thats interesting - thanks Rahl.
I guess you need to search for 'pressure fed' I just searched for cam tensioners.
Interestingly - your part # is 930 105 058 03,
but if you look at this one
https://www.pelicanparts.com/More_Info/93010505803.htm?pn=930-105-058-03-INT&bc=c&SVSVSI=0580
It has the same part # on the body as mine. So it is the same unit. Different part #s.
Thanks Rahl.
Hopefully no more stuff ups. Dropped the timing gear shaft key down the hole, later followed by a cam case nut. Both retrieved luckily.
Of course I promised myself I wasn't going to drop anything down there. Oh did I mention the chain ramp as well.
Make haste slowly.
Regards
Alan
Old 02-03-2024, 05:23 PM
Thanks Rahl.
Make haste slowly.
Regards
Alan
What was that about drinking beer and working on the engine at the same time? lol
I've been there myself. Dropped a magneto part down inside the accessory case of my airplane engine. Spent hours trying to fish it out (alternative is a teardown/rebuild).
Hangar mate came over and got it on the first try.
Glad you got your parts out.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 02-04-2024, 11:51 AM
Alan L's Avatar
Yeah - it is kind of your worst nightmare really - to see something drop down in to the chain case. Luckily they hadn't travelled too far and were visible.
But when I first tore this engine down - shortly after buying the car, it was clear it had been patched up in a hurry to get sold. After blowing a piston. RTV seeping out of every joint - choose your colour, it had them all. When I got to the crankcase I found a timing lock pin. Obviously they just gave up trying to find it, knowing the car was about to be sold.
Waiting for some bits now. Had hoped to have it running by now and possibly make the next meetings.
Too rushed. Shelved that plan and will work on it at a sensible pace. Too many mistakes.
I inadvertently cracked the cam bolt off using a flywheel lock. Not thinking. Forgot that is straining the chain. Got a new one on order as well as the proper cam tool.
Every time I use my home made cam tool (which is awkward) I keep telling myself, just one more time - won't need the proper tool. Now I have ordered it, it will probably sit in a drawer for the rest of its life.
Regards
Alan
Old 02-04-2024, 01:45 PM
