-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   ARP head stud torque value (http://forums.pelicanparts.com/showthread.php?t=1155672)
Alan L 02-01-2024 10:42 PM
I have 23.5 ft lb in my notes. Not sure if this is the book value - suspect so. But I have ARP head studs/nuts. I had a feeling they had a higher torque value?
Alan
proffighter 02-02-2024 07:20 AM
Hi Alan
Watch this:
https://tech.arp-bolts.com/instructions/204-4206.pdf
Br
Roland
Alan L 02-02-2024 10:16 AM
Awesome - very helpful - thanks. Could not find in my folder of notes - but looks familiar.
They sure felt like more than 23 ftlb.
Alan
mikedsilva 02-03-2024 03:23 AM
That seems like a LOT more torque doesn't it?
This previous thread has corrspondence from ARP....
https://forums.pelicanparts.com/porsche-911-technical-forum/1115709-arp-head-stud-torque.html
gsxrken 02-03-2024 05:53 AM
38lbs is crazy. These engines grow too much at temperature for that. And the ARP studs probably stretch less than OEM making it worse. I’d proceed with extreme caution, Alan.
Alan L 02-03-2024 10:17 AM
Hmm, food for thought. I just don't recall what I used last time. My hand written notes are at 23.5 but that is the book value.
The ARP sheet link that proffighter sent does look familiar but I can't find mine.
FWIW I left the other two heads intact and took my chance torquing the one I removed, then fitted the cambox. A bit back to front. What I did was insert the cam and torqued the cambox down in 3-4 steps, checking the cam rotation at each step. It torqued down fine - no binding along the way.
But what I will do now is back all the heads off and retorque to a lesser value. I used 35 ft lb on this head.
it does seem a lot when torquing them - but that is a seat of pants assessment.
Alan
