Porsche 935's Avatar
Would love to see the horsepower gains, no intercooler vs a2a vs a2w.
3.3 ltr, stock compression, efi, twin turbo - no intercooler.
Old 11-13-2025, 03:26 PM
Brando
quattrorunner's Avatar
I had a time with no intercooler on a 3.0 930 engine and back to back with one. I felt more lag with one but it felt better with it same boost. I was only running .6bar. and immediately put a .9bar spring on and never looked back.
That's when all my clutch problems began if I remember correctly. Next was transaxles.
Turbo powa!
1977 911s. it's cool
Old 11-13-2025, 04:17 PM
I run water methanol injection and no intercooler between 1.15 and 1.7 bar of boost. So interested in his power gains with the two types of intercooling. And if it was tracked how hot would the water in the system get?
Old 11-15-2025, 10:01 AM
Chain fence eating turbo
Unfortunately, I dont have a dyno sheet from the A2A since the car is cursed. Clutch never holds for various reasons on dynos.
Weird how the clutch can hold on the street and dragstrip, but not a dyno with a huge drum (Dynojet).
Dyno #1 by PO - metallic 6-puck had milled away the flywheel surface until the clamping force was compromised slipping
Dyno #2 - my fault, told the owner of the mobile dyno that dont worry about slipping clutch as it is Kevlar when backing up long ramps. Reading the internet can really give you bad information (reading Kevlar can slip without burning up).
Clutch slips right at 4500 RPM and bangs rev limiter every time (nearing peak torque according to the fuel numbers) and it was just showing over 400whp at that time.
Dyno #3 - RMS leak plus slipped clutch from previous session further wiped out disc (if you're asking why I went back again, is because the clutch was totally fine on the street and running into the dyno owner again, he offered another 3 runs for free, so I had nothing to lose)
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-17-2025, 03:31 PM
Ok, some new data that has been the best yet................kinda
__________________________________________________ ____________
83F ambient today (not a typo, stupid Texas weather)
Start up and see 87F from cold to fully warm with occasional dropping to 86F.
That is 3-4 over ambient at cruise. Nice!
I was consistently seeing 20F before over ambient at cruise, so I think I have gotten more water into the system by rerouting the remote fill cap (although I know its still not 100% full).
Then I do my favorite pull. Drop to 3rd at around 68-70 MPH and hold it to redline.
I see a peak of 106F. That's a rise of 19F over cruise inlet temps and 23F over ambient.
So, from this latest data, I am seeing good cruise inlet temps over ambient, but under 1.4 of boost is still higher than the A2A.
But the caveats are still twofold:
1. No cooling fan(s) on the heat exchanger
2. No idea how full the system is
I am pondering putting a long, skinny rectangular tank (say maybe a gallon or more) in between the shock towers in the rear so the water level will not be a factor. The pump will constantly have water on the inlet side.
To add a fan I have not decided how yet. Real estate is so limited and making an offset sheetmetal shroud is some figuring.
The system works pretty good as it is so I have not been in a hurry to work out all the improvements.
Old 11-17-2025, 03:43 PM
Happiest when Tinkering
gsmith660's Avatar
Good numbers keep going
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-17-2025, 03:51 PM
Yeah, it’s kind of fun seeing gains.
The IC itself looks so good, it’s the heat exchanger side that takes away the fun. LOL
Old 11-17-2025, 04:07 PM
gsmith660's Avatar
You will get it figured out and then it will be all fun. My opinion is all this stuff is fun and challenging I wish I could dig right into this mod I am doing and get it done but I don’t have time before I have to go to work so I am working on the perimeter stuff getting what I can done so when the time comes I just dig in.
Old 11-17-2025, 06:14 PM
Good luck man! Been eyeballing those transmissions myself.
Old 11-17-2025, 08:01 PM
I had a kevlar clutch disc also originally and it would slip under power as peak torque approached on the street. I had to go with a metallic 6 puck to hold the power especially at 1.7 bar of boost. A little difficult driving it in traffic but what can you do as you approach these kind of horsepower numbers. I tried to find a twin disc for my set up but no one willing to make one back then. I enjoy your out of the box approach to the ultimate reliable search for horsepower and street ability.
Old 11-18-2025, 05:11 AM
930 box? I remember GJF saying he had KEP make a dual disc for his G50
Old 11-18-2025, 10:02 AM
Mine is a shortened 930 box so not much room in the shortened bell housing. My chassis is a 75.
Old 11-18-2025, 04:50 PM
I had similar issues with another car that I used W2A IC on it, I have found that when you go for a bigger radiator/HE combo, the more capacity you need for the reservoir, or you will end up with air pockets that will eventually cause higher temps.
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 11-18-2025, 11:09 PM
Good to know, thanks
Old 11-19-2025, 07:44 AM
Thought I would share one more observation.
I noticed that if I keep throttle at say ~0.5 bar of boost, the temps stay dead on cruise temps or maybe 1-2F higher at most.
Old 11-19-2025, 10:58 AM
