Send a message via AIM to Chuck Jones
Intercooler seal.....
I see that the rubber seal around the rim of the stock intercooler has come apart at the corners. Is there some sort of product that you can use to bond the edges of the rubber together at the 90 degree corners? I can see that the PO had some silocone there but it didn't hold.
Most of the pictures I see of the intercoolers show the rubber has come apart at the corners....does this affect the efficiency of air induction? Logic says not...otherwise there wouldn't be so many examples of separated corners....guys would have fixed them.
1987 factory Slantnosed 930 Cabriolet/Guard's red
2002 Midnight Blue 996TT X50
1999 Iris Blue 996 (Dash fire burned and totalled 9/07)
Old 11-02-2006, 11:24 AM
Automotive Monomaniac
Emission's Avatar
It will be a nearly unmeasurable power loss. Use some silicone to shore up the edges if it bothers you.
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 11-02-2006, 12:02 PM
I asked this question several weeks ago on the 911 tech forum before the turbo forum was created. You might search over there as I received some good responses. I ended up using super glue to reattach the corners and applied silicone over the glued corners for extra strength. So far, so good.
Old 11-02-2006, 01:34 PM
Thanks...I'll go look it up on the newly created Turbo forum. Even though it doesn't appear to have much effect on performance, it just doesn't look right. .....BTW...Thanks for the 930 forum Wayne!! I just saw it.
Old 11-02-2006, 01:46 PM
Porschephd's Avatar
Use silicone PASTE during the install and this is not a problem.
Stephen
94 3.6Turbo 6-speed AWD
Old 11-02-2006, 06:27 PM
Is there a particular brand name that's better than another? I'm not familiar with silicone paste...I was about to go use some of that "Gorilla Glue"....but based upon this last suggestion, I will wait for the response. When I looked closely at my rubber seal, I could see that there was some sort of silocone based product adhering to the edges. Do you know how long this paste keeps it together?
Old 11-02-2006, 06:41 PM
Porschephd's Avatar
The past keeps it from pulliung apart. Use a new seal and use the past. I use Wurth brand. Any brand will work I am certain.
Stephen
Old 11-02-2006, 06:48 PM
Junior Member
Inter-cooler rubber
Get some heavy duty fishing line and a needle. Line up the rubber and put one stitch in it before you silicon it. When it sets up, trim back the line. This will give it a little extra holding power. Not more HP unfortunately.
Cheers
Remember, it's not a lie if you believe it.
Old 11-04-2006, 02:39 PM
