Crotchety Old Bastard
RarlyL8's Avatar
That's awsome!
A buddy has modded his turbo engine and is now complaining that the front end is too light in ALL the gears. Headlights in the sky.
Are you having that problem?
How can you keep the rear end from squatting too much and still have a good ride?
Old 11-29-2006, 08:12 PM
WydRyd's Avatar
LOL! Yes, I have the exact same problem... front end gets very light and it looks like your launching at a 30 degree angle.
Mind you, I'm still running OEM Carrera torsion bars (with KONI adjustables), which I think are too soft for the capabilities of this car. I need stiffer torsions, especially in the rear
Would love to do a rear coil-over conversion, but this is a street car, so I may just upgrade the torsions instead
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-29-2006, 08:28 PM
RarlyL8's Avatar
It is common for hi-po 930s to run 30mm bars out back. Mine are 28mm and they're not big enough for my mildly modded engine. My concern was ride comfort when I installed the 28s. I don't want to get into annual kidney transplants.
The next thing I am going to try are adjustable shocks. We'll see how that goes.
Old 11-30-2006, 10:17 AM
adomakin's Avatar
nice one Merv! just one question-is 1.25 bar safe for these engines? im assuming that 1.25 is just for them short blats?
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 11-30-2006, 12:41 PM
WydRyd's Avatar
That's exactly what I'm going to ascertain when I get her on the dyno to verify my mixtures are in check at that boost level.
The high-po guys like Juan Ruiz and Mike Rombotis have been running those boost levels (or more) on pump grade 93 or 94 octane fuel without any dramas. That's on their EFI'd cars, like mine, and have countless drag race events under their belts
Mind you, I don't think it's wise to run that sort of boost on a track, but for pure street which only sees occassional full boost bursts, I don't think it's an issue. Again, the dyno will verify if all is OK.
For me, 1.1bar is plenty powerful. Might just bump it up to 1.25 when I demo the car for joy rides
Edit: Mike was able to run 1.55bar/22psi on pump grade 94 octane fuel in his TT Carrera. The result? 661crank HP & 675tq If he can run that kind of boost safely on pump fuel, I'm sure 17-18psi would be OK
Merv
'89 911 Turbo Cab
Old 11-30-2006, 02:14 PM
adomakin's Avatar
thats what I like to hear Merv!
Andy
Old 12-01-2006, 09:38 AM
