I need gears!
So after a 3-day weekend at Road America I have firmly decided that I need to do something about my stock 4-speed. Worn syncros aside, hitting 4th gear is like putting the damn thing in overdrive... it just slowly builds speed. As a result I probably am leaving 10-15 mph on the longer straights.
Since I have converted my car to a coilover suspension and removed the sway bars, does a G50 conversion become significantly easier (baring the clutch conversion issues)? Frankly the thought of $10+k makes my stomach turn.
The alternatives are a short R&P, which I have sitting on the shelf now, or re-gearing the existing 4 gears.
A friend has a similar 930 to mine with shorter gears and damn does it pull like a freight train straight thru forth.
Any opinions or suggestions would be greatly appreciated.
Regards,
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-30-2007, 07:41 AM
David's Avatar
As a hard core DIY, I've decided to change gears in my 930 box. I can buy the gears for about $400 each for $1200 for 2, 3, & 4th. This way I don't have to reset the R&P (which I understand isn't very DIY friendly), I keep the stronger stock R&P, I still have tall 1st gear to handle my high hp, and I don't have to blow a huge wad of cash like with the G50. The drawback is not having an overdrive like you would with the G50/5X, but I don't plan to take any roadtrips in the 930.
I'm waiting until I have the engine and EFI fully sorted out, so I don't have any 1st hand experience on how it's going to turn out.
Old 04-30-2007, 08:59 AM
David -
have you decided on which ratios you are going to use? Is there a standard 4-speed upgrade set?
Rob Montgomery
Old 04-30-2007, 09:18 AM
David's Avatar
I'm still playing with the numbers. I have a spreadsheet I've been working through the numbers on, but I'd be embarrassed to give it out since it's so jumbled up now.
I think PowerhausII used to show the available gearing on their web site, but I just checked and it's not there.
Old 04-30-2007, 10:52 AM
I agree with David - changing the gear ratio will help a lot, is cheaper & can retain the stronger R&P.
I have shortened by 3rd and 4th, though in retrospect, I should have lengthen 2nd just a bit. I can't remember the exact ratio off the top of my head, but I chose based upon the different tracks that I normally drive.
From memory, I hit 6400rpm right before braking at the bus stop at the Glen. And that is probably the highest speed track that I drive (normally), so I think my gearing is quite suitable.
I believe Guard Transmission also shows the available gear ratio.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 04-30-2007, 01:27 PM
DRV2FST's Avatar
I think short gears are a better option than the other alternatives. I have a stock 1st and a shorter 2, 3, and 4. I had a short R&P before but replaced it with a correct R&P and better gears.
2nd = 16:25
3rd = 27:26
4th = 30:22
I have a spreadsheet that someone sent me a while back. It shows the gears and ratios and charts them for you. PM your email address and I'll send it.
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 04-30-2007, 03:35 PM
Can you do any of the work yourself? If you can you can save a lot of money on a G50 conversion.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 04-30-2007, 04:39 PM
gtu935's Avatar
Send a message via AIM to gtu935
THe 930 gear box is strong. In the old days I regeared mine. I moved 1st way up IX if I remember correctly. I changed 2nd and 4th. pm me if your interested in the gear charts.
South Shore Performance (Facebook us)
Freeport NY
FIKSE Dealer
BBS Dealer
Old 05-01-2007, 06:28 PM
