Nape75'911T's Avatar
low idle......
Hi All,
Just looking to confirm a hypothesis......83 Turbo......stock everything. The secondary hose from the smog stuff was leaking I suspect. Idle was a little high, at 1100+rpm when warm.
I just installed the new BB intercooler, and plugged that pesky hose. Fired up the car, and it's idling very low (300rpm).
So my question is.....if I had a leak and plugged it, would the idle drop, or have I created a leak to cause the idle to drop?
Thanks,
Mark
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 07-27-2007, 07:45 PM
I think I got it....
checked the hoses, o rings, rechecked everything.....idle still low. Sealed it all up and adjusted the idle a little to 950, and it is purring....have to take it out in the am and get it up to proper operating temperature though, to be sure, at 1am, the RarlyL8 muffler wouldn't likely win me any points....
Old 07-27-2007, 10:00 PM
