sudo apt-get purge 930
H.E. question
I have a euro exhaust and it uses heat exchangers with part # 930.211.021.03 and I'm looking at a set to replace mine since they are toast. The ones I'm looking at are part # 930.211.021.01, is there a difference between the two and if so what is it?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Why don't you just scrap the OEM HE's and install aftermarket headers? You'll get better performance/response with the shorter secondaries. Just a thought
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Because I like to keep it as close to stock as I can and I need the heat. Also, I have other things I need to spend the money on. I can get these for $100 in perfect condition.
So, does anyone know if these will work?
