cis idle
Can anyone help on this? I have a 73 2.4 cis with some idle problems.
1. idle doesn't willingly return to idle and sometimes it increases on it own.
2.when mixture is set rich enough to run well the idle surges.
Old 06-10-2008, 12:56 PM
Macht Schnell
les_garten's Avatar
Could be a zillion things, but you may want to eyeball your clutch cable and see if it is interfering with the throttle linkage. Another thought, intake leak.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 06-10-2008, 09:16 PM
I had a leak on the tube going to the turbo from the IC and it caused a variable idle. When I replaced the IC I accidently pinched/cut the rubber O ring and it let ambiet air in and changed the air pressure.
911rudy
Old 06-12-2008, 09:10 PM
