Rear Decklid....Quick Question
Figured I would ask this here as those with a turbo would have the answer.
I have acquired a right side (passenger side) deck lid hinge supposedly from a turbo car so I can mount a second deck lid strut to my 85 911 with a whale tail. Only problem is this.........It was sent to me so I am not sure it is correct. This hinge has a triangle shaped plate that is spot riveted to it. On my left side hinge there is sort of a raised pad that the strut goes in between just like on the firewall. On this right side one, there is just a welded nut on the one side that appears to be where the strut attaches. Is this the right part? Anyone that can snap a quick photo of the way their strut is mounted? The firewall mount on the car is the same on both sides so I would think the deck hinges should be too, no?
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc. |
sudo apt-get purge 930
Pictures would make this much easier.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
You are correct, stand by.
Yes, that looks exactly like my passenger side hinge on my turbo.
I just popped into my garage and took this for you. If it is not the angle you need just let me know and I will shoot from a different angle. Any excuse for me to not have to work on my engine
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
Here's mine.
Now there is another question though. In the post below yours, the strut end is mounted on the other side of the plate. Which is correct? I would imagine that the bolt has a smooth (unthreaded) portion where it contacts the eyelet of the strut, no? (so it can pivot smoothly)
Mine is on the wrong side because the hinge is bent. The one you quoted is correct. The head of the bolt should be inboard.
Once again, Pelican guys come through quick as lightning.
Thanks.
Actually we're Turbo Pelicans, that's where the real braintrust hang out!! ( now go get a turbo and come back to visit LOL)
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Scuffed and sanded it up, primed, painted last night. Got it mounted up today. Works perfectly.
A fellow Pelacanite
So your Carrera is not a sport? Yet it still has the bracket on the firewall to mount the strut?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Package would include what? This car has ZERO options When you look at the underhood tag, it lists the only option as CO2 (cat)
Cynical Misanthrope
My '89 Carrera 3.2 had the bracket on the firewall. I had to fab the right side hinge bracket when I added a Carrera tail, but the firewall bracket was there.
X-1, AFM744, Jon, '92 C2 Turbo JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending... Where my misspent time and money is currently going. |
All the deck and hood shocks use a pin with a groove and that fiddly little clip that ends up jumping somewhere in the engine bay at least once, surely?
'77 S with '78 930 power and a few other things. |
Mine has a threaded nut attached to the outboard side. The driver side has the pin and clip.
The driver side hinge uses a bolt on the hinge side mount. There is a threaded nut to accept it. Since I originally posted this thread, I found out even more info. I was informed by a very experienced and certified Porsche tech and well known rally car builder that the plate was/is used on the right side hinge due to the fact that if they used a mount like the left side, it would strike the 930 airbox. And in looking at the setup, it makes perfect sense.
A fellow Pelacanite
My 3.2 carrera has pins and clips, that car is very very original. As for my 930 there is no point me even looking
