What coils to use on a NA twin plug?
A shop in Hong Kong is installing our latest unit on a NA twin plug car.
MoTeC ECU, everything is fine to 6500, then acts like the rev limiter kicks in. Two days of emails later, he says he finally disconnected the J&S and his Bosch igniters misfire too. His coils have 1 ohm primary resistance. I told him to change to something with 0.5 ohm, but I don't have a part number. Number, please? Thanks much. |
A fellow Pelacanite
My stock 930 coil has a resistance of 0.7 ohms.
I'm sure Pelican could fix you up with one if they wanted to try it. http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ELignt_pg9.htm#item38 Quote:
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 07-25-2008 at 09:43 AM.. |
Coils were not the problem. The tuner forgot that he programmed the MoTeC to rev limit at a certain "water" temperature.
A fellow Pelacanite
Hehe
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
