JHP JHP is offline
headers leaking
Hi
I have a pair of b&b headers with the heat boxes that are leaking.
However, i can not see an visual leaks. So my question is can they be leaking inside the heater box? I am thinking about cutting out the heater box to see but before i do i wanted to check if it is even possible to leak in there.. any welds in there that may crack or is it all one pipe?
also, is there a special method to use to check for leaks?.. I am thinking of just feeling up the header with water?
thanks in advance
Old 07-28-2008, 02:18 PM
A fellow Pelacanite
NathanUK's Avatar
Sometimes they can leak where the heater box got welded to the pipes/tubing.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-28-2008, 02:42 PM
