Certified User
billjam's Avatar
Boost measurement question
I am fitting a mechanical boost gauge in place of clock.
The 12mm vacuum hose from the engine to the brake booster looks like it would have vacuum and boost all the way up to the booster. If this is so, a tee connection in this hose close to the booster looks like a convenient place for the boost gauge connection. This would avoid the need to run a separate small hose through the car from the manifold to the gauge.
Any problems with this approach?
Bill
Old 09-21-2008, 03:24 AM
A fellow Pelacanite
NathanUK's Avatar
You can buy the special non return valve that fits in the brake booster. It has an additional small port for your gauge. Saves hacking the car.
IA and NHS do them.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 09-21-2008, 04:08 AM
Crotchety Old Bastard
RarlyL8's Avatar
Kits are available for the brake booster T.
I personally don't like cutting into the brake system. My gage has a braided stainless line running through the tunnel back to the BOV housing. No cutting of any sort, just plastic zip ties.
Old 09-21-2008, 04:54 AM
E-85 sippin drunk
turbobrat930's Avatar
I totally agree on this one. I ran a separate line right from the bottom of my I/C, thru the center tunnel, right up to the back of the guage.
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 09-21-2008, 09:54 PM
