source for tach signal in engine bay?
Is there an obvious/easy source I can tap into in the engine bay to pick up the tach signal/same signal as the tach would receive?
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
By the CDI box and running on the frame rail towards the front, there us a black wire with a purple stripe. If I'm not mistaken, that wire goes to the tach. It also has a connector in that same location.
Thanks for the tip! I will check that location for the wire and see if does the trick.
Wer bremst verliert
Coil neg terminal. Depends on your signal requirements. WHat are you using it for?
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Using it for the Digital WUR RPM module.
Signal requirements...I'll have to check the manual later, unsure off the top of my head.
