I'm out of ideas
Ok guys I've been slowly getting both my cars running.. Trac dog is running like a champ. Now back to the black 86..
It was running like crap,, everyone said it had a boost or vacuum leak.. so I replaced everything in the system.. gaskets on the injector blocks, all O rings, rebuild the diverter valve, confirmed the waste gate is functioning correctly.. So now the engine runs great,, idles perfect, just doesn't develop much past .4-.5 bar boost.. I'm at a total loss as to where my leak can be.. I don't have power either ,so I know it's not a bad reading on the boost gauge.. Any ideas ?? Can a turbo have a leak ? I have an extra one I can throw on if that seems logical ... Help!!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Pressurize everything past CIS @ 0.8 bar and listen for leaks. That's only sure-fire way of finding leaks.
Spraying starter-gas around doesn't really work. When I was working for SAAB couple years ago, this is factory procedure for finding leaks. We even had factory tools + pressure regulator to do this. You remove the hose from air filter, pop a disc with a nipple and pressurize everything. Any leak will be imediatly noticeable. Look for Alan's posts here, he fabricated his own adapter to find leaks on his engine using this method. Regards,
Thank you for your time, |
Ingenieur
Don't forget to check the backpressure (pressure between turbo outlet and cat), if you still have a catalyst on your car. My car has a fitting for this purpose (don't know if all years and models do). With enough misfire and/or rich operation the catalyst material (substrate) can break up and cause alot of backpressure. No enthalpy across the turbine = no boost!
7.0:1 > 11.3:1 > 7.0:1
"doesn't develop much past .4-.5 bar boost"
"I don't have power either" Lack of boost compounded with the engine not making much power (given the low boost) makes me think timing way out of whack, or perhaps something like fuel starvation. I don't recall your history, but did your cam timing get upset? What was changed when this issue occured? Last edited by Jim2; 04-17-2009 at 07:32 PM.. |
Nope timing checked out fine,, The engine is running fine except there's no boost.. starts and idles like a champ, accels to 3000 rpm fine until the boost should kick in. Just hooked up a plug from the flexible elbow from the intake and am pressurizing from the waste gate hose.. I need one more hose clamp and should be able to pressurize the whole system now.
Delayed timing = more heat into headers = quicker spoolup Regards,
Worth looking into if you have a cat. |
What gauge do you have showing the boost pressure? sometimes you're there and the gauge shows .4 ~.5
Game plan is tomorrow I'll have a set up to fully charge the system and listen for a leak. Just need to run to Home Depot for a ring clamp. T
The stock gauge is not that accurate. It is sensitive to too many factors. You might be getting all the boost but indicating less...
Smart quod bastardus
It could be the throttle plate not opening fully? Did you check throttle movement?
Also, the diverter valve could be not sealing properly....you mentioned rebuilding it, but did you make sure it was sealing/done 100%? Other than that, if you have no vacuum leaks to make it run poorly via bad oring seals in the intercooler plumbing, then it has to be specific to the boost system. How did you verify wastegate function?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
