Do I need a new alternator?
Battery at rest =12V
Idle 950 rpm no load =13V
Idle 950 rpm with load =12.2V (high beams and radio on)
Same numbers with and without load at 2000 rpm's also.
I'm pretty sure the answer is yes from what I've read in the archives....
Maybe I'm wrong?
Thanks,
Drew
86 930 Autronic EFI
Drew
86 930
Old 05-25-2009, 11:07 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
No you need a new battery... Try charging it up overnight with a charger,
The fact that you're getting an extra 1V is indicating it's charging,, You may have a dead cell as it should charge to 12.8 volts or so
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-25-2009, 11:26 PM
Off to the garage to charge overnight.......
Drew
86 930
Old 05-25-2009, 11:58 PM
A930Rocket's Avatar
Check all your connections as well, including the starter. That's where I found my problem.... after I swaped out my alternator.
Old 05-26-2009, 06:49 AM
