Tomy's Avatar
Intercooler with CryO2?
I just read article about cooling intake and intercooler with CO2 What do you think could it work with ours intercoolers? Or maybe some of us use it?
I think about intercooler cooling. They claim to go up with more than 50% of efficiency.
I will not install it probably but it is interesting in compare with new hi-efficiency intercooler upgrade.
TET930 996 TT 2003 X50 996 GT3 2004
930 1988 black on black -fast...
944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2
911 S 1970 Targa /ex porsche werks car!
911 S 1969 Targa (under rebuild)
Old 08-29-2009, 09:17 AM
Tomy's Avatar
I read more about this system and I think it is not usefull to us as :
*CO2 works as a fire extinguisher and displaces oxygen.
*Engines use this oxygen, combined with fuel, to make power.
Ingesting even a small amount of CO2 into the air intake will slow car down.
*It will be impossible to use an intercooler spray bar without ingesting residual gases from the intercooler spray to airfilter....
Old 08-29-2009, 09:29 AM
You could do the same thing with nitrous oxide. A 10lb bottle fill is usually around $35.
The bottle pressure is similar, it's icy cold when going from liqued to gas, and any vapor that eventually gets sucked into the engine intake will definately not reduce power.
Old 08-29-2009, 11:17 AM
R.I.P.
drmatera's Avatar
they are not spraying it into the air intake. It's just cooling the pipes and intercooler. Co2 is cheaper than nitrous.
with that said it's a gimiky ricer bolt-on that has no real practical use
Old 08-29-2009, 11:32 AM
reread what i wrote... where did i say spray it into the intake?
i have seen some drag racers (on TV) spray nitrous over the intercooler with a spraybar as another cheap and quick way to cool it.
no new ideas here, it's all been done before.. lonnng before the internet.
and anyone off the street can buy nitrous oxide from a speed shop, easily.
Old 08-29-2009, 12:18 PM
930gt-40r's Avatar
now imagin running that system on nitrous and then add some meth injection on top of it...
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 08-29-2009, 03:05 PM
NOS911
mxessin2's Avatar
Send a message via Yahoo to mxessin2
Does anyone know how much it cost to fill a 10 pound bottle of Cry02 ?
My Pelican Page
Old 08-29-2009, 03:54 PM
A930Rocket's Avatar
How long would a bottle last is another question? We were kidding about adding it to the cars for the track, but you would be out of NOS long before the 30 minute session was up. Then you would just be carrying around extra weight.
Old 08-29-2009, 06:57 PM
R.I.P.
drmatera's Avatar
you didn't say it. Tomy did. I don't recall singling you out
Old 08-29-2009, 08:07 PM
A portion of anything you spray on the intercooler willl make it into the air intake, since it opens into the area below the intercooler, unless you rig some kind of duct from the air filter straight to the A/C Condensor (if you have A/C), or straight to the grill.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 08-29-2009, 09:02 PM
A fellow Pelacanite
NathanUK's Avatar
These were my exact thoughts on this.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-29-2009, 11:24 PM
beepbeep's Avatar
It would work great for a couple of minutes! (as long as you don't such that sprayed CO2 into intake, which is probably what would happen).
Looks like a complicated band-aid solution to the problem that was solved long ago.
Thank you for your time,
Old 08-30-2009, 01:58 PM
R.I.P.
drmatera's Avatar
bingo
Old 08-30-2009, 04:53 PM
