digital display in the speedo on the turbos
Does someone have the link to the guy that was converting the speedos with the multi displays. It was controlled by the stalk switch.
thanks. |
www.InYourFaceGauges.com
We make a Boost gauge for the 930 Clock location here is a set of RUF gauges we did for a Rennlist member last month and a tach for the 930's Thanks Dave InYourFaceGauges.com 770 519 2666 |
Is the one where you can toggle through and get different displays, a/f, cht, etc. through the turn signal stalk? If so what are the different displays.
Here is what InYourFaceGauges did for me. They do top notch work.http://forums.pelicanparts.com/uploa...1251847803.jpg
http://forums.pelicanparts.com/uploa...1251847820.jpg In the clock position, I have a single gauge and can toggle between boost, AFR and EGT. I can also choose to look at all three together. |
super cool!!! i love your setup man!! especially the RUF gauges !! it may not be traditional but i like what you did with their digital readout putting it over to the right and leaving that gorgeous tach unmolested! well done!!
Thank you!!
I think It cost something like $650.00 for the basic conversion.
I thought it would display more functions. I have a friend who stuffed a 3.8 motor in an early car and is looking to monitor a number of functions.
It can monitor and display 4 parameters simultaniously. You can have up to 32 sensors input.
http://www.plxdevices.com/multigauges.html see DM-100 I've got one displayed in the lower portion of my tach from dave at in-your-face. |
| All times are GMT -8. The time now is 11:50 PM. |
