Driving over 120 mph....
I use my 930 for high way driving so very often drive over 120 mph. In case than I have only 100 miles from home to German non limit high way I use to drive fast if possible.
I just wonder how you feel yours cars over 120 mph and what suspension set up you have. My car is still stock but lower then Euro set up a bit 24.4 " rear and 24.8 front with lot of negative camber front (-1 degree).My experience is that till 115 mph handling and response are perfect over this speed front going to be lighter and above 130 I have feeling on steering wheel that car is moving left right a little but still is OK.
TET930 996 TT 2003 X50 996 GT3 2004 930 1988 black on black -fast... 944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2 911 S 1970 Targa /ex porsche werks car! 911 S 1969 Targa (under rebuild) Last edited by Tomy; 09-10-2009 at 09:30 AM.. |
Blackbird Pilot
Stiff, planted and firm as can be over 130, coil over setup front and rear (Bilstien RSR's with raised front spindles) 350lbs front springs and 500lbs rears, those should go up to about 800lbs rears for less softness.
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us |
These cars all get lighter at the front than the rear, that is sort of a signature 930 feeling at speed, even the new GT2s... |
Dixie Boost Hooligan
[/QUOTE]I just wonder how you feel yours cars over 120 mph and what suspension set up you have.
My car is still stock but lower then Euro set up a bit 24.4 " rear and 24.8 front with lot of negative camber front (-1 degree).My experience is that till 115 mph handling and response are perfect over this speed front going to be lighter and above 130 I have feeling on steering wheel that car is moving left right a little but still is OK.[/QUOTE] The specs of your set up (heighth and camber) seem fine. You do not mention 'tow' or 'caster'. You should have front set to maximum caster for straight line stability with total tow in of 1/16. Rear camber set -1 degree with 1/16 to 1/8 total tow in. Have you had your car corner balanced? This will also provide stability and sure footedness in all situations. As mentioned in previous posts it is the nature of these cars to get light in the front end at speed. The rear tail provides a goodly amount of downforce rearward and various aero aids are available to add downforce to the nose. Last edited by turbo3six; 09-11-2009 at 01:17 PM.. |
At speed
I have run 183 at Silver State open highway event with good stability in a 1988 930 I used to own. Low front end stance and stock 930 wing. Tires at 34lbs. Recommend front splitter. Am going to run my 1979 at the Texas Mile in a month. No rear spoiler at all (though I will take along my small spoiler just in case) since I want to see how car runs with no rear drag from 930 wing. Did fabricate front splitter. All amature stuff with no common sense or intelligence applied.
EPS
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Tommy;
My '87 is also lowered. I'm running Bilstein Sport Shocks, 23mm and 31mm torsion bars, 22mm rear Tarett adjustable sway bar, and adjustable rear swing plates. Using stock toe, camber, caster settings. Over 120mph with OEM front valance and OEM tea tray, front felt a little light and darty. I installed a new fiberglass Euro 930S front valance and had more than a few heart palpatations while >120. BIG CHANGE! Front end got REAL light and I really had to fight it to keep it straight. Extremely minute inputs were required and the feeling was not confidence-inspiring. The center oil cooler opening is letting more air under the nose than can be dumped out under the car/through the fenderwells. E P Slick couldn't be more correct; the front end needs a splitter. I ordered mine last week from GT Racing.
Scott - 1987 930: 3.45L Supertec engine w/GT3 crank, California Motor Sports upgraded 930 trans, modified suspension, Zuffenhaus 9's and 11's, black on black..."The Black (Financial) Hole"
![]() I doubt there is a time I don't do some cruising at 120-150 every time I take this car out which isn't often enough. Ruf type front and rear spoilers and TurboS tail. As a matter of fact taking the beast out tomorrow morning. Supposed to be in high 50's. Sometimes I wish I hadn't taken out the adjustable boost.
63 356 So Called Outlaw 76 930 Last edited by Les Paul; 09-11-2009 at 01:30 PM.. |
Metal Guru
I hit 120 last weekend while doing some testing and I wouldn't have known it without glancing at the speedo. Car was as solid as a rock.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Scott
Have you any picture of your front spoiler ordered from GT Racing?
TET930 996 TT 2003 X50 996 GT3 2004 930 1988 black on black -fast... 944 TURBO S 1989 WHITE/BLACK # 1 944 TURBO S 1989 #2 911 S 1970 Targa /ex porsche werks car! 911 S 1969 Targa (under rebuild) |
No pics, sorry. Go to www.gt-racing.com. On their homepage, go 2/3 of the way down the page, on the left, click on "911 Parts". Go to pg. 9. I now have the front valance that's on the white 930, p/n 48a. Difficult to fit, but I like the looks. (It doesn't appreciate gettin' bottomed out though.) The "splitter" I bought, and I know will give me some down force, is on pg. 8, p/n 44c. It mounts horizontally to the bottom lip of the front valance. There are many guys on this forum that use them. Search the forum. Good Luck!
Smart quod bastardus
here is mine going 120mph up thru the last bend in the esses at Watkins Glen.
It was pretty stable and the front feels tight, but this was with completely stock trim and suspension at USA ride height....which is too high in my opinion. Lowering it should only make it better.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
How many of you have calibrated your speedos. Most read high by at least 10-12%. It's simple to do. Just take apart the speedo, insert a variable resistor in place of the fixed resistor and use a GPS to calibrate. Then use a little glue on the pot to keep it there.
IC data sheet for UAF2115 http://www.datasheetcatalog.org/datasheets/700/489248_DS.pdf It's the resistor off pin 4 of the ic. 120-130 ohms. So pick a pot with say a 200 ohm range.
Norm '86 930 AEM Infinity 6 - Twin Plug 3.6L - DBW - JE Pistons/LN Eng. Cylinders - Pauter rods - GT3 Crank - GTX3584RS - ID1050x Injectors - Ported Intakes - Custom Intake Manifold, exhaust and intercooler - 993SS cams - ECUMASTER PMU-16DL HRE Wheels 560R 8.5x18 ET25 (Front) 11x18 ET0 (Rear) |
Same here, we are having a 1 mile event here in Florida and I will see what my car does, do you or any of you have a photo of that "splitter" mounted on the car ? What else can be done for those high speed runs ? |
Thank you for your time, |
I am not an alignment expert but I believe:
A little toe front and rear adds to stability. Max Caster up front adds to stability. -1 deg of camber is not very much in the front. Near -3 I have been told may effect stability. Corner balancing helps stability. Keeping air out from under the front helps stability. Lowering the front to much (more than Euro Style) can contribute to toe change (bump steer) which can negatively effect stability. There is more like shock rates, spring rates, spoilers... |
Front Spitter
Juan; No pics of splitter on car; haven't gotten it from distributor yet. I hope he doesn't mind, but check out x98Boardwell's thread on the 930"S"front spoiler at http://forums.pelicanparts.com/showthread.php?t=473561&highlight=front+splitter.
This is why I hate this freaking forums !
![]() Very interesting ! I saw that they sell for around $200.00 do I have any other more economical solutions ? Is only for one day
Manassas, VA
Les Paul (great handle),
Do you still have your adjustable boost. I need one... PM me. Thanks, Mark
1991 964 Polar Silver Metallic Turbo Coupe |
For one day you can use a piece of plywood (as long as you don't mind a lot of ribbing). If you want to get creative, you can cover the plywood with fiberglass and finish it so you can reuse it anytime and make it look good.
thats a start, I'm thinking some sheet metal, but how do I figured the size ? meaning from the ground to the splitter ?
