Replacing brake lines-can't loosen
I order SS lines from our host but I can't get the old lines off. I purchased an 11mm flare wrench and I got one end off but I started rounding over the other end. I didn't want to ruin them so I stopped for now. I did let it sit for a day after spraying them with liquid wrench. What is the secret? I don't want to use heat.
When searching on this site for suggestions I learned some are having problems with the new lines not matting up with the stock fitting so getting the lines loose may be only the first battle.
Old 09-21-2009, 06:43 PM
Metal Guru
911nut's Avatar
You can use a propane torch to heat the nut up. Make sure you only heat up the nut, not the line. Do not heat to cherry red. Soak first with PB Blaster or Kroil.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 09-21-2009, 07:15 PM
Registered Abuser
MT930's Avatar
PB Blaster & very little heat. Use the flair nut wrench !!!! on anything soft. Heat scares me on the hard lines. Don't freak if one gets bunged up, they can be replaced, just cost some bucks & time. Take your time.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 09-21-2009, 07:39 PM
I tried the flare nut wrench and liguid wrench penetrating oil. Maybe PB blaster or Kroil are better huh.
I found this while searching the net for oil comparisons. It is kinda off topic but interesting.
"The April/May 2007 edition of Machinist's Workshop did a test of penetrating oils where they measured the force required to loosen rusty test devices. Buy the issue if you want to see how they did the test. The results reported were interesting. The lower the number of pounds the better. Mighty interesting results for simple acetone and tranny fluid!
Penetrating oil . Average load to loosten. Price per fluid ounce
None ................. 516 pounds .
WD-40 .............. 238 pounds .. $0.25
PB Blaster ......... 214 pounds .. $0.35
Liquid Wrench ... 127 pounds .. $0.21
Kano Kroil ........ 106 pounds .. $0.75
ATF-Acetone mix.. 53 pounds .. $0.10"
Old 09-22-2009, 04:33 AM
cycling has-been
bkreigsr's Avatar
Mine were stuck beyond loose when I bought my 77, and I went through the usual Kroil, PBplaster etc. etc. with the appropriate soaking periods.
The only thing that worked was to use a carbon fiber disc in the dremel and cut down toward the fixed fitting.
Continue with the flare wrench, and it should split open at the new cut mark.
As long as you're replacing the lines, no reason to preserve the old ones.
Another method is to cut the lines above the fittings and get a socket and/or box wrench on it.
good luck
Bill K
Old 09-22-2009, 07:06 AM
Use a flare or "line" wrench and instead of gradually increasing torque on the wrench with your hand, take up the slack with one hand and hit the wrench firm with the palm of your other hand.
If there isn't room for both hands to do that a hard rubber deadblow hammer works for hitting the wrench too.
This way almost always works better than torqing it loose which sometimes rounds off the points of the nut.
You'll have to do it a few times before you get the feel for it.. and if you're doing it 40-48 hours a week it becomes second nature and doesn't hurt your hand at all.
Anotherwords, "break it free"
Old 09-22-2009, 08:25 AM
I'll give that a try, thanks!
Old 09-22-2009, 10:32 AM
copbait73's Avatar
A team in the turbocharger reman plant found H2O (cheap ole water) to be the best penetrant and lube for rusty bolts.
Old 09-22-2009, 02:22 PM
