mark houghton's Avatar
Bastardized and seriously devalued...
I presume that some of you have seen this one...another well-intended conversion to American V8 muscle. Now, if I were to agree with this approach to bastardizing a perfectly fine machine, I would say that he did a good job...but for the front hood mods to accomodate the radiator. Hideous, IMO. I think I would have opted to mount the radiator horizontally with a hood scoop feeding it, vs. cutting out the entire top of the hood.
Regardless, the thing probably rocks but in an Americanized kind of way completely off from the mark. What do you call this thing - a Fordsche? As to re-sale value, you decide.....
YouTube - porsche 930/v8
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 02-04-2010, 08:15 PM
UNDER CONSTRUCTION!
carrera turbo's Avatar
well it looks to have been a 912E at one point of its life. look at the gauges in the first few seconds of the clip.
not sure what to think about the rest.
cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 02-04-2010, 08:25 PM
A930Rocket's Avatar
Info said it was a 76 I think.
Anyway, I think the guy dud a good job. He may have bought a car with no motor and V8's are cheap. On the hood, there are a lot of race cars, including Porsche's, that have that configuration to allow air through. Maybe painted mesh screen would help hide it.
Old 02-05-2010, 04:07 AM
Eye of the Toiger
matty74's Avatar
each to their own, he should turbo charge it
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 02-05-2010, 04:15 AM
Looks like a Olds or Buick 215cu all aluminum 8. Not many know it, but Olds offered an f85 with a turbocharged v8
Old 02-05-2010, 04:50 AM
spoke's Avatar
At least he can see and reach the spark plugs.
Ditto on the comment of cheap big HP. There's nothing wrong with a big V8 although I would think the gearbox would need some taller gears for the lower revving V8. It looks to be well done.
Coming from the 914 world, there are lots of 914 V8s but then again the 914 started life with an anemic T4. The 930 chassis does represent a viable sports car platform.
Old 02-05-2010, 04:53 AM
Mabey "Buicorsch" . That little alum. buick engine would build some serious little engine hp. with a couple of turbos.
copbait73's Avatar
Worked with an engineer who built one with large single turbo, Bendix injection, special180 degree crank, 525HP. Installed in a home design, SCCA ASR back in the mid '70s. It really showed the visiting aluminum big block Mclarens who owned the long main straight.
Old 02-05-2010, 02:34 PM
copbait73's Avatar
12 years before the Porsche 930 Turbo, the GM Olds F-85 Turbo, 215ci (3.5L) ALL Aluminum, very small block V8.
Installation had sidedraft carb, Garrett turbo with integral wastegate, water/methanol injection intercooling, and boost retarded ignition.
Old 02-05-2010, 02:55 PM
That's what I am talking about!
Old 02-06-2010, 05:09 AM
Looks like the little Buick aluminum V8, which was also used in older Range Rovers up until the new body style that came out in 2003.
Rover even increased the displacement to 3.9L, 4.2L and finally a 4.6L. The 4.6 came with beefed up rods, crank, block and cross-bolted mains. Not a bad engine.
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 02-06-2010, 08:35 AM
Oldsmobile sold that 3.5 liter aluminum V8 to Rover way back in the late sixties or early seventies.
I still remember reading an issue of Road & Track in the late seventies where some guy bought one of those Olds 3.5 liter aluminum V8's really cheap from a rotting Olds in a junkyard, tuned it up with better cams and put it into an early Lotus Espirit.
Road & Track said it was one of the best engine transplants they'd ever seen at the time. The V8 fit in the mid engine car really well and the Espirit's performance was so much better with the lightweight aluminum pushrod 3.5 liter V8 than the overhead cam 2.2 or 2.4 liter Lotus 4 cylinder that was in it.
Old 02-06-2010, 09:51 AM
7.0:1 > 11.3:1 > 7.0:1
Know a guy who stuffed one of these motors into a formula car. He said in England there are still lots of performance parts available for them.
Old 02-06-2010, 12:11 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
If I am not mistaken it was Buick who sold the 215 to British Leyland back in 64 ( I could be wrong either way it was a GM sales) . These motors were used in the Triumph T8, MGB C GT, Range Rover, ect. The all aluminum V8 was actually lighter than the MGB 4 cylinder and was the reason MGB built the MGB C because the inline 6 they originally built in the MGB A GT was too heavy, it required a revised front suspension using torsion bars and the car suffered handled poorly. The 215 molds wore out and since new molds had to be made displacement was increased as well as emission equipment. The gas crunch came right when British Leyland took over the engine program and hurt their efforts. They end up keeping the engine and it served them well it their trucks and larger cars and eventually exclusively the Range Rovers. I thought at one time using a Buick 3.8 from a Grand National for a swap. Not as light but definietly plenty of HP, BIG HP!!!!!!!!
It changes from time to time.....
Old 02-06-2010, 12:56 PM
At one time I conemplate doing this engine swap in my '73 MGB...way back in my pre-Porsche days and before I T-boned my 'B' at 60mph. Pretty hot setup.
I still have my 1960 MGA complete with the stock 4 banger puting out maybe 80 horses. Made for tooling around the country roads, being cool, picking up chicks (well, except "chicks" won't have anything to do with a 56 year old geezer).
Old 02-06-2010, 06:45 PM
fat cab's Avatar
found it in our car's for sale. http://forums.pelicanparts.com/porsche-cars-sale/524492-time-let-her-go-porsche-v8-price-offers-taken.html
Old 02-07-2010, 07:33 AM
One less pure 911 in the world improves our resale values! Kidding...it's sort of like dumping a glass of water in the ocean.....
Old 02-07-2010, 01:21 PM
HoyaBear
hoyabear's Avatar
Send a message via Skype™ to hoyabear
YouTube - Renegade Hybrids LS-3 930 Slant Nose Dyno Runs
This one is actually pretty sick. As much as I love the sound of a turbocharged boxer 6, I love chevy V8's. I've always loved how Porsche's handled and how Vette's can hammer down. Maybe one day I might try to Frankenstein an LS-7 into a 911 donor built up like an IROC car... Wouldn't be "cheap" but would sure be interesting and wicked fast!
'86 930: 3.4 Andial build, Web GT2 Evo cams, Carrillo rods, ported/polished heads, MSD 6530, B&B headers/exh + intercooler, K27HF, 1 bar spring, Tial wastegate, Andial FE, Lindsey Fuchs. Back in black!!!
Past:997S cab; '88 930; '86 951; C5 Vette; 4th Gen Z28; 3rd Gen Trans Am GTA; '71 Z28
Old 02-07-2010, 06:47 PM
