wastegate not opening,..
1980 930 euro
i dont know why i just realized this, i guess i had my mind on fixing other problems with the car but,
i have a wastegate dump from fabspeed on the car, and realized the last few times i have driven the car the wastegate has not been opening,...boost has never went above .8bar (assuming there is some sort of safety thing so motor doesnt blow)
is this a blown diaphragm? i have a new line connecting into the intercooler with new clamps, so no leaks there,...
is there anything else that could have "broke" inside the wastegate? i should be aware of,...
i will be upgrading to a set of fabspeed headers in the new future and wondering if now is a good time to replace with a 46mm tial, or just rebuild the stocker
Old 10-10-2010, 02:50 PM
how do you know the wastegate isn't working?
Old 10-10-2010, 03:01 PM
cant hear it, waste dump tube is clean as a whistle!, no black carbon or anything
i have had external wastegates on my last two turbo cars, and you could hear them from 30 miles away when they opened
i would think this would be the same? esp with only 4 inches of pipe coming off of it
Old 10-10-2010, 03:06 PM
for a quickie test jam a potato in there, take it out and floor it...
no potato later and .8bar boost? why worry about it.
Old 10-10-2010, 03:14 PM
mark houghton's Avatar
If your wastgate isn't opening, then you would overboost beyond .8 bar and the overboost protection circuits would kick in and shut down the engine. On the flip side, if your WG was leaking or stuck open, you would not be able to reach .8 bar.
Sounds to me like your WG is working just fine.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-11-2010, 04:53 AM
Groovie Ghoulie's Avatar
Are you expecting the huge PSSSSSHHHHHHHHHH sound? I have a buddy with the shortie WG pipe, and he does not get that sound either. I think its normal.
Old 10-11-2010, 05:55 AM
hahaha, i dont know what sound you are trying to make there, i am not talking anything like a ricer blow off valve or anything, i just know when my wastegate opens on my other cars, you can hear the thing from miles away,..its deafening
Old 10-11-2010, 06:29 AM
torresmd's Avatar
I can hear when my WG opens. My exhaust note increases quite a bit with a sudden onset.
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 10-11-2010, 08:49 AM
wwest's Avatar
1980 930 euro
"..I have a wastegate dump.."
Something like a BOV, Blow-off-valve, to DUMP pressure the instant the throttle valve closes...? If so it sounds as if it's partially (full..?) open full time.
Old 10-11-2010, 09:27 AM
see this is what i am talking about,..
i would expect with two weeks of driving, there would be some carbon build up in the wastegate dump pipe, and its clean as a whistle
Old 10-11-2010, 09:54 AM
Then one of two things: In your two weeks of driving, you're not on full boost often enough to open the WG and "dirty up" the pipe....or, you're running too lean on boost and don't have any unburned fuel left to coat the pipe with carbon.
As I said earlier, if the WG is not opening then you have to ask yourself where that boost is leaking out at. Even the old stock 3LDZ turbos will overboost without a functioning WG.
Old 10-11-2010, 10:24 AM
