930porsche
Transmission oil type?
On 930 what type of transmission fluid should I use when changing oil? Your recommendation will be very helpful.
Thank you. |
If you don't mind the price swepco 201 is very good and seems to be the usual internet flavor of the month.
plain old inexpensive nothing fancy non synthetic valvoline GL5 is also very good and thats what everybody including the race teams used back in the seventies and eightees. it doesn't have to have green, blue, or red dye in it to work. |
930porsche
Transmission Oil type
JFairman, no I do not mind about the price. How much do I need for a total oil change?
A gallon or 4 quarts.
You'll have around 4 or 5 ounces left over when the transaxle is filled to the bottom edge of the fill port with the car level. |
930porsche
Transmision oil type
JFairman,
Thank you for responding so promptly. |
How about Redline 80-90 GL5 synthetic?
I have had good results in VW and Audi transmissions with their GL4 synthetic. |
resident samsquamch
Yep, Swepco 201, is all I have ever used. And you'll have a bit left over if you buy the gallon size (I always get it from our host). Also, be sure you loosen the fill plug on the tranny case first, before the drain plug! Sure would suck to drain the fluid, only to find out the fill plug is seized/galled and you can't drive the effin' car!
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
I've used Redline synthetic GL4 for limited slip diffs in BMW differentials with a ZF limited slip carrier that is exactly like the Porsche unit only smaller with only 2 clutch rings instead of 4 and that worked fine, and I've used Redline MTL in BMW transmissions and it worked really well, but BMW Getrag transmissions have used Borg Warner brass cone type synchro rings since 1972 or earlier in the 2002 and synthetic is fine with those synchros just like its fine in the Porsche Getrag G50 transaxles with brass Borg Warner synchros. |
Don't know if this will help you out........
http://forums.pelicanparts.com/porsche-911-technical-forum/490399-ultimate-transmission-oil-thread.html
2275T MS EFI '65 VW Panelvan http://www.vvwc.ca/minstone/ |
Wo ist die Rennstrecke?
I use SWEPCO 210 which is 90w140 I think. I use it because it works and I haven't had to rebuild or work on my tranny even with the HP I have and all the DE's I've done. |
If your car is a 89 or with a g50 swepco is not recomended
The porsche steel synchro rings and brake bands will wear faster using synthetic because they will be slipping more and not gripping smoothly and engaging if you use them... and time adds up.
