Turbo Gravity Drain, does it work?
A number of you guys have built your own turbo systems for 911SCs and Carreras. I'm wondering how successful you've been with the discussed gravity drains to either a chain cover or sump plug. Is one recommended over the other for any preferred reason?
The project is a custom turbo system on a 3.6 in a 993 chassis. I don't want to have to integrate a 930 scavenge pump or an electric pump if I don't have to. |
I actually removed my electric scavenge pump and ran the drain to the sump to make room for my 993 AC condenser. So far so good, but I am careful to cool the turbo before shutdown and I use Mobil 1 to hopefully reduce coking risk.
http://forums.pelicanparts.com/uploa...1273116685.jpg |
I drain mine into where oil drain plug usually goes with -16 line. Had to restrict oil feed line down to -3 with garret turbo and I havent had any problems.
I wonder if the supply line has more potental for colking after shut down as the oil might sit on top of the turbo.
The drain oil level should drop down to the level of the oil in the crankcase if plumbed into the bottom. I like the idea of draning into the chain housing hoping for an air gap between the bottom of the drain line and the case residual oil level if the turbo is hung high enough. Just my two cents. |
Jim if you can raise the turbo higher and drain into the timing cover I feel this is the best location. I been running this way for 6 years now and never looked back. As long as you have 1" above drain location you are good. I have been using -12 for the drain. I had it at the drain plug for a while but it would back up into the turbo's once in a while when in the twisties.
http://forums.pelicanparts.com/uploa...1273167011.jpg
I know this is a picture of a twin setup but just to give you an idea. I also fabricate manifolds that bolt to the bottom of the turbo that gain you more clearancehttp://forums.pelicanparts.com/uploa...1273168015.jpg Here is a drawing to give you an idea. Bacisally it is just a fabricated hard line and then AN from there to the final location. |
Someone recently posted some pictures of a factory 934 or 935 showing the turbo drained to the sump. Also, didn't the earliest Turbo Carrera's have the sump drain as well without an additional scavenge?
My take on the drip tank to scavenge pump adaptation is that it was to effectively drain the turbo on shutdown and reduce latent heat oil coking. For my use, sacrificing the drip tank and scavenge pump for an effective AC seemed worthwhile until my next rebuild at which point I will likely go to a mechanical scavenge system without sacrificing my cam sensor. However, I don't track the car or even AX at this point which I think would have a significant impact on the decision process. |
When Jerry Woods rebuilt my 3.5 he ditched the scavenge pump and fabricated a a custom sump cover.They were talking about making a small run for sale. Don't know if that happened. http://forums.pelicanparts.com/uploa...1273207804.jpg
However, that was not directly from the turbo. It was from the scavanging pump and instead of dumping it back into the oil tank unfiltered as on a 930. Can we tip the turbo and how much to drain into the chain housing? |
I have run it 3 different ways 1st was drain into the cover worked ok but did not real easy to make leak proof. I then tried into the sump plate which works pretty well but on my stock sc oil pump it did not seam to scavange enough at idle. Then I tried it with my rebuilt engine with the supertec modded sc oil pump and it worked fine at the sump[. I used that for a year but could not get over the fact the oil line was the closest thing to the ground so I switched to a stock 930 scavange pump. that seems to be the best solution for my application it works worry free for me though my car is not a 500 hp monster nor is it a 930 it is just a 3.2 ss sc based engine with efi and a k27-7200 if that matters
Maybe you could post a little info to point me to where I went wrong? This would help so I can delete my previous post in good conscience, so as not to mislead others. This is why no matter how noob the question in the engine rebuilding forum, I always respond in great detail...there's no advantage in sending someone away without the right info...one day they may get a chance to pass it along, too. |
Harold, thanks for the input, proves that back-up under acceleration is not an issue, but I do wonder if Jerry incorporated a "trick" like a standoff tube in the center of the sump plate which is near the scavenge pump orifice. You happen to have had the sump plate off by any chance?
Ben, I believe I had seen you post a WTB ad for a scavenge pump and this is what got me wondering if the gravity drain format had issues. You never seemed to mention a problem earlier on.
So it works for some, but not for others. Perhaps there are small variences which cause go/no go. |
Mine feeds back into the oil sump plug of my carrera, has been that way for about 3 years without a hitch. I maybe wrong here but I think you're safer running a more modern ball bearing turbo as the oil supply is greatly reduced so there will be much less oil to scavenge than a K27 (also less very hot oil re entering the sytem)... I imagine you'll be looking at something like a GT40, there is a 993 turbo thread in here somewhere and someone has talked about their, very successful, conversion.
I haven't had much of an issue with Ben's old setup I get a little smoking when I start it up after sitting for a month or so but that is it
http://forums.pelicanparts.com/uploa...1273321743.jpg |
If one just runs a line from the turbo to the sump, that oil has to go somewhere. Will it back up into the turbo? |
| All times are GMT -8. The time now is 12:04 AM. |
