Infidel
Looking good, cooler looks like a good design, nice big surface area, not too thick, nice end tanks.... Are you going to be able to log intake temps after the cooler, so you see how well it does its job?
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
R.I.P.
oh yes, I have my Davtron dual sensor gauge and also an IAT gauge thats part of my EFI system and can be datalogged. I datalogged some 3rd gear runs from 2000 rpm to about 4500rpm with the old setup right before we took her apart. I'll be able to see some concrete results with the new combo. good or bad
You're not powder coating the IC are you? That takes away from the heat transfer.
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
R.I.P.
One of the innovators in intercooler technology here in the US powder coated all his intercoolers. Do you have data that proves otherwise? I'm all ears
Infidel
Secan don't have any paint on theirs, I would do the same
R.I.P.
well, they wanted to keep the price down
Infidel
Of course, didn't think of that...... Paint away mate, do 20 coats
The whole theory of cooling relies on getting the heated air in contact with as much surface area as possible, then get the cooling air in contact with as much surface area as possible. The material between the two 'airs' needs to allow as much thermal transfer as possible, that's where guys like Secan have made the improvements. Any extra material is just an insulator and impedes thermal transfer. When you look at a 'price-no-object' Secan if they thought a coating would be of benefit, they would use one.
Who sells those Davtron dual sensor gauge
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
From the Bell Site:
R.I.P.
WinRice, thats my plan. I certainly don't want to pay for a large custom intercooler then diminish it's potential in the name of "bling"
Juan, I buy them right from Davtron. They are an aviation gauge company but are great to deal with. |
With your logical approach so far, I thought that was the goal.
R.I.P.
It is amazing that there is very little information on the web about this. Bell Intercoolers says coating the tanks is a non-issue but spray a light coat, if any, on the actual core. I may have the tanks done in silver so there's very little contrast. The black on my fan shroud looks rediculous and the intercooler would have looked great but oh well. I don't want the polished look so thats out. I may have some finished pics of the fab work today. Can't wait to drive her, may have t postpone the coating
R.I.P.
ok, headers and intercooler brackets are back from the coater. It all looks great but we have 3 broken studs to deal with before the headers go back on.
Nice work!!!
I like your IC design a bunch. Well thought out. BOV? |
R.I.P.
thanks, Yes the BOV flange is on the intercooler around the backside. I was going to put it on the pipe but wanted a cleaner look. I'll snap a couple pics of the intercooler off the car.
R.I.P.
pics. notice my aluminum exhaust system next to the intercooler? No signs of heat fatigue what-so-ever
Again, nice.
Nice end tanks. Should flow more even through the cores than most and be very efficient if ducted properly. Is the IC supply tube larger than the exit? It dose look a bit large and would be nice if there was a tapper in the up tube for a little less volume and less turbulence from the quick cross section change. Nice work. |
R.I.P.
The inlet and outlet tubing is the same size, 3". In fact the tanks are pieces of 3" tubing cut length wise and welded to the tanks. It creates a smooth surface for great flow. I did want to make the inlet tubing 2" from the turbo to the cooler to keep velocity up but in the end we just stuck with 3" to keep from screwing up the air flow with steps. We used a silicone 2" - 3" transition to connect it at the turbo. Hope to have some good datalogs for comparision to the double stack intercooler/K27 7200 combo. Gotta love apple-orange comparos.
R.I.P.
BTW, it sits just below the tail "grill". I plan on running a perimeter of foam to seal it to the wing for optimum flow. It doesn't cover the whole grill opening, should I block off the rest so the fan can only pull thru it or is it better to leave the rest open?
