Received My PPI Results Today 91 964 Turbo
I received the call this morning on the results of the PPI on a 91 964 Turbo with 73K miles that I'm interested in buying. I asked for a compression & leak down test, had them look at a small oil leak and why it had a pull to the right.
The pull to the right was from a bad alignment, they did a 4 wheel alignment to solved the pulling issues. The oil leak is from one of the valve covers and is very slight, and suggested not to replace the seal at this time. Here are the compression/leak down readings. 1 125 5% 2 125 6% 3 125 4% 4 125 5% 5 125 6% 6 130 3% The tech said they were good numbers with 73K miles. Do those numbers look in range for this year and miles? Thanks
16 VW Touareg 05 Porsche Cayenne S 87 Porsche 930 84 VW Rabbit GTI |
BMAN when I bought my 83' 930 it had similar results with no more then 4%. I personally think those are great numbers, but I am sure some other guys will chime in here.
1996 Porsche 911 2013 BMW 335xi - Wifes car 2007 4Runner - 4x4 for Colorado snow Past: 1988 Venetian Blue 911 Targa, 1983 Black 930, 1984 Black 911 Coupe |
Thanks guys... Can't wait to pick it up on Saturday. Now I need to order my new wheels, RH 3.6L
Yes, you are correct. I updated the 930 to the 964 look just for them
I always thought that was a beautiful car! Very tastefully modded.
87 930 Coupe Red, K27S, Kokeln IC, Rarlyl8 Headers system, Tial 46MM, .9 Bar. "Lola" 81 911SC Coupe Guards Red, Stock. "Zippy" |
![]() e170drvr- Can you tell us about your Rarlyl8 SSI exhaust system? Is it posted on another thread? Len
Thanks...
Curious BMan you sold your 930 not all that long ago after putting alot of work and $$ into it and now you are buying a car that is pretty close to a 930 but looks the same to your previous 930. Just want to try something a generation newer?
P.S: The compression and leak down look fine!
Ole Skool - wouldn't have it any other way |
Congrats!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
C2T's are great cars!
After the next project
Sweet
Bernard,
Glad to have you back in the mix. I sold my 930 and am looking for a 996 TT convertible now... just havent found the right one. I have been told by (Neil Harvey.. I think I'm saying his name right) and some very other reliable mechanics that as long as you are under 10% on leak down that you are clear with no issues. They said some newer Porsches can have 8-10% with less than 10k on the clock. Just another tid bit of info. Take care, Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel |
Hi Bryan,
Well I never went anywhere just didn't post much after I sold the 930. I really started to miss it and went on the hunt for another turbo and came across a 91 Turbo that I felt would fill the void I picked it up today and feel good about my decision I made. I'm going to give her a good bath tomorrow and yes, I'll post pictures
Open question - when you reference leak down results, are you referring to an engine at operating temp or a cold motor? Franz Blam Racing tests them cold and suggests that numbers higher than 10 are perfectly fine. |
On both of my PPI I had to have the car dropped off the day before so the engine was nice and cold.
