-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   3,6 P/C and heads question (http://forums.pelicanparts.com/showthread.php?t=562878)
totle 09-06-2010 01:33 PM
Is it possible to fit P/C and heads from a 993 3,6 l engine on a 3,3 turbo engine?
If possible, what needs to be done to make it fit?
Reaper930 09-06-2010 01:38 PM
Sure is, but you'll need a 3.6 intake setup, which I happen to have one sitting around.
totle 09-06-2010 03:38 PM
Thanks Gab.
Thinking about shopping some 3,6 P/C and heads for a future upgrade
jcge 09-06-2010 03:42 PM
I think 993 3.6 uses a 90mm head stud spacing and the 3.3 uses 86mm....
Not sure if relocating the studs in the case is achievable
