jsveb's Avatar
manual boost CTR question
Hi
Rookie question -beware.
I have a manual boost knob. I just want to be certain about the operation of this.
I want to "close" it, minimum boost.
Can you confirm that by closing it (turning it clockwise) I'll reduce boost?
It is a classic Porsche/Ruf type controller.
Jesper
Old 10-27-2010, 08:22 PM
Clockwise should turn the boost level down. Try in 1/2 turn increments and check you boost gage to make sure your going in the right direction.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 10-27-2010, 08:36 PM
Here is a photo of a Ruf boost controller:
Old 10-27-2010, 08:52 PM
Max Sluiter
Flieger's Avatar
Looks like the Ruf means turn right to go faster. Clockwise=higher boost.
Old 10-27-2010, 08:54 PM
jsveb's Avatar
Thank for the feedback.
I just realized the the abbreviation I used for control (CTR) is misleading in relation to RUF. Sorry didn't think about that.
Flieger, it sure looks like it is clockwise=more boost on that RUF controller.
Mine is a much older type though. will get a pic now.
Jesper
Old 10-28-2010, 07:08 AM
jsveb's Avatar
picture of my boost controller
Old 10-28-2010, 07:10 AM
jsveb's Avatar
I'll try that
Cole
I'mgonna try that. Today is raining real bad
It'll have to wait.
Jesper
Old 10-28-2010, 07:12 AM
Tinkering Pays!!
mooney265's Avatar
I have the silver one... CW to lower boost and CCW for raise boost... I remember by thinking "tighten turns off the boost" just like a faucet turns off the water...
I put a black mark on mine [like the minute hand on a clock], so that I know how many times I'm turning it.
In order to get 0.95 BAR boost, I tighten all the way and "loosen" a full 2.5-turns...
It has a locking screw [alan head] that I use to lock it in place... I have a 3-yr old that sits back there and I'm afraid he may go to turning it - so, that eliminates that possibility...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 10-28-2010, 07:16 AM
jsveb's Avatar
I got my question answered -thanks
I'll do the same. The allen screw is tight now for the excact same reason
Before I posted this thread I noted the position of the dial, but then I wasn't certain, and decided to ask you guys.
Thank you
I'll keep the faucet closed for now.
Jesper
Old 10-28-2010, 07:31 AM
Tinkering Pays!!
mooney265's Avatar
just understand that by fully closing the valve, you're boost will then default to the wastegate spring. If you have a 0.7 BAR spring, then that will be your boost.
also, your WUR will still fully enrichen the mixture, but will be mixing with less air; therefore, you "may" be running very very rich...
just food for thought...
Old 10-28-2010, 05:06 PM
jsveb's Avatar
Thank you for pointing it out.
I don't know the AFR as it is, and I hope on the rich side is better than to much "lean" boost.
Jesper
Old 10-28-2010, 09:01 PM
