-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Broken key and door handle (http://forums.pelicanparts.com/showthread.php?t=577545)
IMR-Merlin 11-30-2010 05:40 AM
Originally Posted by WPOZZZ (Post 5700376)
Do you have access to dental picks? Those are really thin and may be able to get them out.
oddly enough I do, my girlfriend is a dental hygienist.
IMR-Merlin 12-09-2010 02:28 PM
Ok, I was able to borrow some door picks from a locksmith friend in the business. Took less than 10 minutes to pick the broken key out. Seeing as this key would activate the ignition with just a screwdriver, I am assuming the key is still good. Any ideas where I can get a key blank for an 82 euro car? Think a local key maker or an Home Depot will have a blank? Then I can take what's left of my key and have a full key cut.
WPOZZZ 12-09-2010 07:53 PM
A locksmith should have the generic blanks on hand. However, after you get a good one cut, get a factory blank from Pelican and have it cut.
IMR-Merlin 12-09-2010 07:58 PM
my plan exactly. Get a cheap one cut to verify function, then get a set (2) cut with a factory blank.
