Smart quod bastardus
fredmeister's Avatar
missing sheet metal on 3.3 liter turbo or not?
In the teardown of my 3.3 liter turbo I noticed that the sheet metal that usually runs across the 3 cylinder barrels that covers the case thru bolt nuts is missing.
This is an item that is very important on 911SC engines but I am not sure if it was missing due to previous rebuild negligence or if this was a factory change along with the removal of upper cooling fins on the turbo jugs.
I am trying to post photos of the sheet metal from our hosts catalog below:
Am I ok to go without this or was it missing and do i need to order it now? Going to build with 3.4 liter Nickies once I have sold enuff sperm and blood to make the cash, ha,ha.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 12-20-2010, 10:20 AM
beancounter
jwasbury's Avatar
Fred,
If your '79 was stock, running the original half-finned jugs, then you will not have this piece.
If you are planning on 3.4 liter fully finned nickies, you will probably need to get a complete set of tins from an SC or 3.2 carrera. I suspect that you will find (like I did) that the tins for the half finned cylinders don't fit correctly with the fully finned ones.
link to my thread on the subject:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/524074-cylinder-cooling-tins-can-i-get-ruling.html
I'd start looking now to source a good used set. Hopefully this info can save you some time. I didn't discover this until I was reassembling and it set me back a couple weeks. I also wasted $ having my old tins powder coated.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-20-2010, 10:51 AM
e170drvr's Avatar
Hey Fred, what CR are you going to run? I have been going for months trying to decide what to build. I just talked to Troy at EBS today, and he is suggesting sourcing some 3.2 jugs and having the Nikasil them to 3.4 and use JE pistons. I am going to run 8:1, twin plug at lower boost. I know Keith, and Chris at turbokraft have suggested this might be a really fun street build.
Eric
Old 12-20-2010, 12:17 PM
A930Rocket's Avatar
When I reinstalled mine on the fully finned jugs, I had to trim one or two in just a spot to get them to work. Is this what everybody else did?
Old 12-20-2010, 01:43 PM
