Gary (guest)
Guest
Posts: n/a
Is this the replacement I should be installing for my 1985 911 915 transmission? 999-113-185-40-M30. Also what metal ring are you referring too?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Shifter Rod Seal Replacement
Old 02-08-2011, 10:45 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, that is the proper seal for your shifter selector. If you look at the inside of the seal, there is a little metal band in there that is integral to the seal - you want to make sure that this band comes out with the seal when you remove it.
- Wayne
