lite75's Avatar
electronic csi controller
Greddy rebic IV fuel injection controller used to control a frequency valve to vary the control pressure at the fuel head. Uses map and rpm signals along with frequency valve settings to create a smooth A/F ratio throughout the entire rpm range. $550.
75 930, 76 930, 83 SC EFI turbo
Old 03-14-2011, 07:42 PM
Got Boost?
IMONBOOST's Avatar
Can I use this with my factory installed Frequency valve used for lambda control? Obviously assuming I eliminate lambda control.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 03-14-2011, 07:47 PM
lite75's Avatar
Yes, if its connected between the fuel distributor control pressure side and the return line to the fuel tank your original FV should work.
Old 03-14-2011, 09:04 PM
