proffighter's Avatar
one more
Roland
930 Turbo '81 Too many modifications to list
Old 06-25-2025, 01:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #741 (permalink)
hmm. For some reason 5MB does not work.. So a bit smaller now
Roland
Old 06-25-2025, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #742 (permalink)
Engine wiring almost finished. this time I decided not to pack every wire into one protection hose I made a couple of them, each function/area has it's one hose. This way it's much easier to have access when needed. I also go without rubber grommet at the connectors. Each wire has a silicon seal in the connector, that's enough. I prefer this, as it avoids water inclusion, same as the protection hose. Wires are FLYY, which ist modern standard (finer strands and pvc covering) ecxept the SDS injecton sensor and injector wires, those are high quality as well and supplied with SDS injection.
Roland
Old 08-12-2025, 01:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #743 (permalink)
Some more pics
On most pics there are still a lot of cable ties, which I only used to route the wiring and get an idea of the final position. After I fitted only two (bigger ones) in this area
Roland
Old 08-12-2025, 01:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #744 (permalink)
Because my LH Fiberglass Fan Block-off is quite old and brittle and the RH is still steel I ordered some Sheridans from PP. On the first view, they look quite ok, but when started to fit, they turned out as terrible...
RH needed lot of trimming, but that would be ok, even if I think (as the OEM part fit's really nice and is easy to copy) it could be better from beginning. There are no marks where the mounting holes should be. Also the measurements differ from OEM part, what I cannot understand, no variation needed there. All in all, it's ok, but far away from nice. The biggest issue is that there is way too much epoxy (or polyester) in the inner corners, especially at the lower mounting latch and the inner side of the top bar so you can't get close enough to the engine shroud. about 5mm away. When you tighten the bolts on top, you deform the bar (presses down), so there is alway tension on it (or you leave it loose...)
Will post pics, when both are fitted.
LH has same issues but more than that,the are several angle errors (guess they took out to early out of mold and it warped while harden. Also radius to fan housing is bad and the inner lower area to fan bas has a huge gap. Too much trimming here. Also the area for the bolt to fan housing at the side is to short, not possible to make a hole but only a slot.
Angle issue:
Comparison to old FG piece (which fit's 99%):
Roland
Old 09-02-2025, 05:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #745 (permalink)
For now, I leave them but will make my own copies with FG myself. As it's quite a bit of effort to make good molds, I'll postpone that...
Roland
Old 09-02-2025, 05:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #746 (permalink)
Here now some pics installed of LH
Roland
Old 09-02-2025, 12:37 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #747 (permalink)
Some more DIY hollow screws and vent line for Wastegate.
Tial screws vs DIY, Stock line vs DIY and mounted on wastegate
Roland
Old 10-12-2025, 11:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #748 (permalink)
Banned
Chuloway's Avatar
POR-15 is the real deal, especially on Italian cars they can be notoriously prone to rust. You've gotta follow the instructions to the letter, though, and make sure the surface is properly neutralized before applying it. My mechanic uses it on all the Italian cars he works on and swears by it. You're doing a great job tackling this project
Old 10-13-2025, 01:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #749 (permalink)
Fear No Rust
fourblades's Avatar
Some more amazing work!
You are really going all out on the weight savings.
Are you getting close to being done?
John
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/1105122-driver-survivor-black-1987-930-build.html
Real IMSA 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=91937
Basket Case 914 restoration: http://www.914world.com/bbs2/index.php?showtopic=79106
Old 10-15-2025, 04:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #750 (permalink)
John
Thank you
Well the "problem" is, that everytime i made something I see the next part that i can customize or DIY like the vent tube.
One done, another ahead
To answer your question: No not close, but progress is there. Engine is beside some little details almost ready to fit in the car.
Roland
Old 10-15-2025, 12:16 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #751 (permalink)
After weeks of removing old paint off the intercooler I found time to paint. Looks quite nice to me
It was a big mess to get all the the paint stripper residue from the cooling fins. Multiple bathing in nitrothinner, flush with water and compressed air. Everytime there came some flakes of paint. After about 10 cycles it was done...
Then next "issue" was right around the corner:
When I bought the fuel lines and fittings at Summitracing, I also bought some alumimum plugs, one for the IC M10x1mm thread... BUT what's wrong with them (the supplier)??? Imperial allen size on a metric thread??? WTF... Now I have to borrow that (in Europe not that common) imperial allen key from somewhere. I am gonna ask on of the muscle car owners here.
Roland
Old 10-27-2025, 06:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #752 (permalink)
DIY wrencher
Gotta love the engineers that came up with that kind of specification...
Imperials allen keys are about €10 for a set on Amazon however, even the Amazon basics set is not bad at all.
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 10-30-2025, 08:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #753 (permalink)
To support oil inlet tube I set a Tubtara in the camshaft housing
Test fit, looks fine. Spacer is will be anodized later
Roland
Old 11-16-2025, 02:22 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #754 (permalink)
When I did my EFI conversion many years ago I was working at the Swiss VCE Market Company and had access to a huge parts warehouse. There I took the hoses for fast idle valve routing. Those are quite old now and I was not that happy with the layout and valve (way too big hose diameter).
So I replaced this
with this (one side is already machined, as I like it more that way)
both sides machined
Roland
Old 11-16-2025, 02:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #755 (permalink)
To avoid issues when a hose needs to replaced by exotic hose, I decided to use OE 964 Turbo setup, but with after market silicon hoses (OE is way to expensive)
Set contains too much hoses as 964 Turbo is still with K-Jetronic, but is still much cheaper than buying single hoses.
At that time I made also a manifold inlet port due the different hose size. So I had to make another one to fit stock diameter. Removing the old one went fine,just a litte heat and correct choose of tool
New one
Because the valve is not at the same position as stock (and different layout as well) I had to cut the hoses to fit new valve. Also i made the port longer. This way I can use stock hoses if needed.
And this is the result
Roland
Old 11-16-2025, 02:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #756 (permalink)
one more pic
Roland
Old 11-16-2025, 02:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #757 (permalink)
When preparing engine related parts like oil lines to be ready for mounting when engine will be back in car, I rembember that I wanted to replace oil inlet tube (the one replacing the oil cooler) by a lighter one.
Steel version i have since decades
So I bought a aluminum tube with aluminum nut a while ago and thought I have only to cut to the right length and make the pipe bead... But then I realized that the old one (like stock) is 28mm OD while the aluminum one is only one inch/25.4mm...
So how to solve this? I decided to make an adapter sleeve and I made it with ID 25.35mm. This way I could shrink it on the tube and it will sit tight on it.
Heated the sleeve and cooled the tube down. Then quick push the sleeve over the tube before heat transfer.
Done
compared to the old one
And a lot less weight
finally test fit
Roland
Old 12-09-2025, 12:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #758 (permalink)
