i know its been asked,...how much fluid for 930 trans
every thread i have read says to just fill it till it starts to drip out the fill hole...
1. my trans is out of the car, and back from a fresh rebuild
2. i want to make sure i order enough fluid (swepco is sold online, so i wont be able to run back and forth to store)
1980 930 transmission. thank you. i really need to get my hands on a manual.
Old 01-09-2012, 10:25 AM
Manual says "Approx 3.7 L SAE 90 oil of API Classification GL 5 (or Mil-L 2105 B).
Ken
1986 930 2016 R1200RS
Old 01-09-2012, 11:04 AM
just under a gallon goes in.
Old 01-09-2012, 12:13 PM
Did mine...
on the weekend. Since the tranny was out of the car, I flipped it on it's side and put the whole jug of Sweptco in. Once it's installed, I'll pull the fill plug and see what comes out. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 01-09-2012, 01:14 PM
Just make a note in your logbook or tape a note to the steering wheel. That's an easy one to forget in the scheme of things.
Ken
Old 01-09-2012, 01:45 PM
that is why i want to fill it now, i also dont want it sitting around for a couple months with no fluid in a cold, damp garage
Old 01-09-2012, 02:09 PM
i changed my trans fluid over the weekend also, I have a 87 930. I pumped in Swepco until it started dripping out but it looks like less than half the gallon jug was used. Did i do something wrong? It was on jack stands with a slight rearward bias? I guess i put something like 1.5 liters in there max.
Old 01-09-2012, 06:21 PM
Did you make certain that all the old fluid drained out? Like others have stated, mine took almost the full gallon. 1.5L is way too little. I don't think a slight rearward tilt is going to make that much of a difference. I would try removing the drain plug and catch the newly added fluid into a clean bucket. Make sure it is all drained out and refill it with new fluid and/or the previously added fluid if it is clean and not mixed too heavily with old fluid.
Mike
1986 930
Old 01-09-2012, 09:17 PM
Jim:
The Old Sled is also an 80 ROW with the original 4 speed. I just filled the trans and it took just short of 1 Gal. I used a long flex funnel and filled until fluid started running out, I continued to let it drip into a catch can until it stopped, stuck my finger in fill hole and the fluid was still at the hole.
There was just less than a quart after I finished.
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 01-09-2012, 09:55 PM
sudo apt-get purge 930
equality72521's Avatar
Originally Posted by cole930 View Post
Jim:
Cole
Same for my '79 ROW.
--clutch-monkey
Old 01-10-2012, 05:40 PM
