1/4 Mile AND Dyno testing the 930
Recently finished building my 930 and finished with the dyno tuning and wanted to get some real world track tuning done. This was 135 mph run, however the objective was to leave very easy and just run it up through the gears for data logging and tuning. Three passes were made with no boost changes.
JRod Joes Silver Porsche 930 Turbo (2) - YouTube This was running against a very fast late model Corvette with slicks and what sounded like open headers. He shot out on me good, but the horse power of the little Porsche was a humbling experience for him. Later he wouldn't even acknowledge my existence, go figure.:) Joes Silver Porsche 930 Turbo (3) - YouTube JRod |
Jrod,
Love the second video because you tee'd it up perfectly. Great sounding and fast ride. I am sure you will see several people post wanting photo's since you only have 6 posts... I would recommend getting those in order. Congrats on a great car and win!!! Any HP figures? What has been done to the beast? Cheers and welcome, Bryan |
Here is the dyno graph at .7 and 1.4 bar with a spike of 1.6 at peak boost.
http://forums.pelicanparts.com/uploa...1326330885.jpg |
Looks good Joe! How have you been?
Eric Hood |
Hi Eric, good to hear from you. How are things with you? Did you ever finish your project?
http://forums.pelicanparts.com/uploa...1326331598.jpg http://forums.pelicanparts.com/uploa...1326331618.jpg |
Very nice..thanks for posting.. Great dyno figures as well.
joe great ride. where in fla are you located?
Nice work jetjox! Fantastic car and sounds spot on too. What time did you run down the strip? Cheers
Yes, I'll post my build sheet tomorrow for you guys
JRod |
Great results. How have you handled the high boost.
500 hp at 0.7 sounds like it breaths really good. |
JROD, specs of the build, please...I am considering variable boost controller so I can turn up the boost at higher speeds. Running 500WHP at .8Bar, but in 3rd -5th could go higher. Nice work and great video!!
NICE!!! :)
The vette guy :( I guess he wonders "How the heck did he catch me???!!!"http://forums.pelicanparts.com/support/smileys/sad2.gif |
Hey neighbor, I work in Sarasota and live in LithiaSmileWavy
Nice ride! Is it an EFI conversion and did you do it yourself? I ask cuz I'm working on one too... Thanks for sharing & see at the track...JK:p |
That's awesome!!
Did you just buy the car or were you considering selling it? |
Nice! Good to see our porsches beating a vette.
Here is a list of what I did to my 85 930 during the overhaul. I removed the engine and trans for a full teardown, once apart I found several problems that needed to be addressed. I also had the opportunity to make improvements to enhance reliability and performance. The list: Machined the cases for windage (Boat tailed) Performance increase Cases cleaned inspected, Cam housings cleaned, piston squirters cleaned Valve relieved the pistons for bigger cams Changed Crankshaft (std) Installed new Carrillo connecting rods and bolts New Main bearing, Rod bearings, Intermediate shaft bearings New cyl base gaskets used Deck height checked and compression calculated 6.8:1 New Racing cam chains( better strength) New chain rails New GT2 EVO Cams from DRC Cams in Ca. Big perf increase over the old 964's that were in it. New oil return tubes New gaskets, seals, and o-rings throughout New chain sprockets 935 Rocker shaft seals Cylinder heads flow tested and CC’ed Cyl heads machined for twin plugs per cyl Cyl heads and cylinders Nirosist ringed for sealing under high boost (935 style) Valve job done 3 angle 935 sparkplug hold downs New racing valve springs installed (135lbs seat pressure) New Raceware head studs and fasteners installed Balanced Crank, Rods, Clutch and Flywheel New ARP Flywheel bolts installed (Stronger Than stock) New Alternator installed New Oil pressure sensor installed New Magnetic Crank sensor installed (Electromotive) New lightweight High Torque starter installed (Saved 7 lbs) New starter ring gear installed New custom Fuel rail made New fuel filter element installed Aeromotive filter New 1000cc injectors installed (old were 600cc) New Mocal fuel lines and fittings throughout New Fuel Lab 1500hp fuel pump (Much Quieter than the Weldon Pump that was on there) New fan pulley and belt New AC belt New spark plugs of course (NGK 5671A-8) Replaced some Spark plug wires and ends(All were ohmed) Replaced fender mount oil cooler with a New Front mount Mocal oil cooler and Mocal fittings and lines. Flushed all other oil lines Tilton Oil scavenge pump for turbo oil evacuation New custom built Wire harness with cannon plugs for quicker engine removal New Electromotive Tech 3R System installed with wintech 4 software (The latest from them) New Electromotive Coil packs with the tech unit New Precision Ballbearing PT6765 Billet wheel turbo/ with anti-surge race cover/ .81 hot housing Thermal coated Powder coated valve covers, cam boxes, fan and housing, strap. New Braille 17 lb battery (Stock batt 31 lbs) New Braille batt hold down used (Very nice) New engine sound pad installed New front brake rotors installed New Racing brake pads installed all four corners Flushed Brake system and added Super Blue Brake fluid New wheel bearing installed all four corners New Kuhmo tires (Excellent dry road traction) Transmission serviced New shifter bushing installed 3k in paint work done New hood shocks installed New side mirror glass on drivers side Motor run in, oil and filter changed a second time. Inspected for defects and none found. Removed engine after break in, to retorque heads and readjust valves and change oil Dyno tuned to 1.5 bar Weighed and corner balanced 2595 lbs empty (Very fast at1 bar boost setting) Rockers inspected Mods already done before: Mahle 98MM Pistons and cylinders (fully finned) 3.2 Carrea intake manifold 70mm Throttle body? Custom headers 304ss Heads ported by Essa Custom Intercooler by Essa (very nice) Griffin core Custom air intake with New K&N filter (Essa) Fuel cell 12 gal New Fuel lab 1500hp fuel pump G50 5spd trans conversion (Recent rebuild) Sachs racing clutch like new Custom Flywheel C2 Body work, mirrors,etc... 17" Fikse FM10 Wheels very high quality and very light 993 Rear brake light mod New Sparco fighter race seats with 5 point harness Roll bar color matched silver 935 center consul Autometer Tach with shift light Greddy boost controller Greddy turbo timer RS light weight interior, door panels Autometer EGT gauge Autometer Fuel pressure gauge Custom Aluminum ECU mounting bracket 3.8 RSR Rear wing Weltmeister sways bars front and rear Rear coilover shock conversion All plumbing Aeroquiped throughout Custom 304ss Exhaust with Borla XR1 core, V-banded for quick removal (Essa) Custom Waste Gate dump piping to match exhaust side (Essa) 935 Boost gauge Porsche updated 993 door handles Porsche up-dated 993 mirrors New power window switch’s installed Large under mount AC condenser modification done for more effective cooling MOMO steering wheel Carbon fiber appointments done on interior Custom faced gauges Billet Pedals New fuse block New through bolt o-rings Transmission was rebuilt prior to my owning it by Gokey Performance Trans has LSD Carbon fiber shift knob Weldon fuel pressure regulator (high dollar) Stock 930 Valves were replaced and very low miles on them (Previous owner) |
Nice. Real nice.
I like how more and more people are coming out of the woodwork drag racing their cars.
I get so tired of hearing how the 911/930 is not built for drag racing. Awesome ride! Love it. |
As I was reading your list, your crank is std. 3.3 and your using 98mm Pistons and Cylinders..
You are producing fantastic numbers-hp on a 3.3ltr engine. Am I correct? If you used a 3.6 turbo crank with 98mm Pistons and Cylinders you would have 3.45ltr displacement...I believe Congrats!!! Walt |
Nice! its a very fast 930, no doubt. best ive done to date is 11.3 at 127mph. cis and stock weight. Ive seen 130.1mph but only on a G-tec measuring device. jetjox....... top work mate.
JRod |
JRod |
Hi jetjox. I ran that time back in 2010. A few more mods since then but theres a post with pics and time slips on here under.. quarter mile results... I only did 2passes on the day but the chev boys were pretty shaken up let me say! Torched a blown 6litre holden monaro easy!!!
That is one seriously impressive build. The poor Vette guy had to be one depressed dude. Love it.
Awesome car. I just started on my engine rebuild and I'm getting excited.
Isn't you 6.8:1 compression ratio lower than stock? How does it drive off boost? I thought with twin plugs and EFI it was safe to raise the compression ratio over the stock number. |
JRod |
Bravo!...reads very similar to my build except I have higher stat compression 8:1 and running only .8Bar now...would like to put in variable boost controller to kick in from 3rd - 5th. http://forums.pelicanparts.com/uploa...1326501055.jpg
http://forums.pelicanparts.com/uploa...1326501396.jpg |
jetjox, nice to see another 930 kicking ass on the drag strip. Your power numbers are right where I want to be. did you mention how much boost your were running on the 137mph pass?
I am also glad to hear the EVO cams are working great, I have a set on the shelf for my build. Damn we really have to do a get together for us florida boys. lots of cool 930's coming out of the woodwork |
Jetjox, what is the name of the controller you recommend?
sounds like he is speaking of the AMS500 or 1000. Sebastian from NLR ( the maker of those products) has gone over 200mph on his turbocharged bike with NO WHEELIE bar
| All times are GMT -8. The time now is 11:00 AM. |
