-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Which GT35R for my build? (http://forums.pelicanparts.com/showthread.php?t=682422)
dwoods 06-08-2012 05:26 AM
This is a new build - Full Sequential EFI with Carrera manifold, heads port matched to manifold, twin-plug, 3.5 liter with 8.0:1 Nickies and JE pistons, ARP head-studs and bolts, etc. What configuration of the GT35R should I select? This will be a street motor, so torque, longevity, and quick boost will be the goals.
dwoods 06-08-2012 05:28 AM
SC Cams also..........
rodolf 06-08-2012 06:45 AM
EFI, carrera manifold, twin-plug, 3.5 CR 8:1 and GT35R..... WHY SC cams with all theses great parts !? You need 964 or GT2 cams ;)
GT3582R with a/r 0.82 is a great turbo, from 380 to +500HP... but for 500 you need 964 or GT2 cams.
forte500 06-08-2012 07:15 AM
This sounds exactly like my build....I went with GT35R with , .82 AR, T3 Flange, V-band discharge, single-scroll, and NO anti-surge housing (increases boost spool-up slightly, not needed on these engines). And - no water cooling - left ports open
The difference was AMAZING and full boost just under 3000RPM. Tires will spin and 1st and 2nd, almost in 3rd. Dyno'd at 540WHP at 1.1BAR (max recommended with 8:1 static compr).
+1 on 964 Cams -
I love my build - fast spool/minimal lag, amazing power throughout power-band, and very reliable. If I could turn the boost up, I'm certain the GT35R would pull to infinity.
Best money spent!
1SIK930 06-08-2012 07:33 AM
I'm a little curious about your cam choice as well. Don't get me wrong, I'm not an engine builder, I don't know enough to say good or bad about SC cams on your build.
How about the new GTX3582R?
forte500 06-08-2012 08:05 AM
Considering your build, I think you'll want more steam throughout power band/RPMs which the 964 cams will provide. On a stock build, the SC cams are a bit torquier down low, but you'll have more than enough raw power on the low end. RE: GTX - not sure the juice $$ is worth the squeeze, but can't hurt.
sjf911 06-08-2012 08:16 AM
+1 on 964 Cams -
Best money spent!
1+, this is almost exactly what I am currently in the process of doing with the T3 single scroll 0.82 AR turbine, V-band discharge, and 0.6 AR compressor housing with 3" cold intake. This came highly recommended from Chris at Turbokraft and the turbo oil supply kit from them is a work of art.
911TT33 06-08-2012 08:17 AM
I believe the GTX3582R will flow as much as the GT40R (~700HP), but spool similar to a GT35R.
Tippy 06-08-2012 08:56 AM
A T3 at 540whp?!?!?
What am I doing wrong?
rsrfan 06-08-2012 09:55 AM
Since this is a new build, I would strongly recommend going twin scroll on the Gt35 with the requisite headers. When I finally get around to my EFI conversion, she will be twin scroll. From my research, all else being equal twin scroll should decrease the onset of boost by 5-700 rpm...
rodolf 06-08-2012 09:58 AM
How many psi tippy ? a/r .60/.82/1.06 ? cams ?
Tippy 06-08-2012 10:19 AM
3.4, 7.5:1, stock Carrera intake, heads, and cams, 1-bar from T60-1 (T4/.81 A/R), 1 5/8 primaries, 3 1/2" muffler straight-through, 4" tip.
Have dyno sheet of 427 whp but was said to have done 447.
rodolf 06-08-2012 12:05 PM
964 cams with 1.26mm timing ? With a CR 7.5:1 maybe you can try 1.2bar with 20° ignition timing.
I don't know the T60-1 turbo, it's like a k27hf or as big as a gt3582 ?
Tippy 06-08-2012 12:43 PM
Mu timing is way above that with single-plug and it's equivalent to a GT35 - just a tad smaller.
rodolf 06-08-2012 01:16 PM
Try a little more boost. With my 964 cams, 3.4 single plug and gt35 i get 496rwhp at the dyno with 1.2bar.
forte500 06-08-2012 02:22 PM
Sorry guys...T4 flange (larger).
forte500 06-08-2012 02:33 PM
Frank Forte GT35R 930 turbo - YouTube
This was at .8BAR and before tweaks to tuning
Tippy 06-08-2012 04:09 PM
That makes a whole lot more sense! :)
TurboKraft 06-08-2012 04:29 PM
Hi Doug,
The GT3582R with the standard T3 inlet GT turbine housing will get you to 15psi boost by 3000-3100rpm and 500-520rwhp comfortably on pump gas from your 3.5L. Two recent GT35R 3.3L engines with port work, SC cams, and flat 930 manifolds.
- 502hp/493tq at the wheels
- 500hp/488tq at the wheels
Both on West Coast 91-octane pump gas.
We've done as much as 540rwhp on pump gas from mild 1994 3.6T EFI engines (SC cams), or built 3.3L EFI engines running the flat manifold and bigger cams (964 or TK-EFI).
Example of recent 540rwhp -- see Kelly's 930 EFI conversion thread: http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/640609-taking-efi-plunge-4.html
3.3L, ported heads, flat manifold, but 964 cams. His turbo is Turbonetic's version of the GT35R in a marginally smaller A/R turbine housing (0.77).
sjf911 -- glad you like it!
GTX wheel or not to GTX wheel... the $600 question (approx. cost difference). On a 3.5L with SC cams and a Carrera manifold, I think you could run it. Make sure you don't get boost creep.
If chopping the headers to twin scroll it, we'd configure it with a T04 flange.
b930 06-09-2012 01:24 AM
I run a GT3582R 0.82AR turbine with T3 inlet, viand out let and 2" compressor discharge. Open water ports, with EFi and SC cams on otherwise stock motor. 1 bar by 3000rpm, builds strong from 2200rpm. Pulls very hard to 6500 rpm limit. Cams are timed mid to late (1.57 from memory). No oil blowing issues issues at all. Car LOVES the low back pressure exhaust side, lots of low down torque off boost and lovely swelling of torque, not on/off.
I use GSF headers and a F46 tial with .8bar spring and using a turbosmart EBC. I get a little boost spike at 1 bar but no serious creep at my power levels, but know others have with the GSF set up.
very impressed with the turbo though, its killer.
