Anyone Know Who Makes This Manual Boost Controller?
I want to replace it with the same one. I just recently got the car and today I took a look at it. It states on the top to pull to adjust and when I pull it up and try to turn it, it just turns freely, wont stop no matter which way I turn it.
http://i414.photobucket.com/albums/p...rdlight002.jpg |
Hard to tell from that pic alone. There are two types 1- is ball and spring which uses the adjusted spring pressure to control the pressure to waste gate and are fast acting at set pressure. 2- is more of a controlled leak. Adjustment opens a vent to increase boost pressure and if vent is closed more it lowers boost. Not as fast or controled to waste gate.
I know that didn't answer your question but there are many different places to buy these. If I wasn't on my phone I would google for a link for you. B |
Looks like the one from Turbonetics.
Turbonetics... got 1 same as that one
Thanks guys... I'll need to take a look at mine again. That one looks to have 3 ports where I thought mine has 2.
That is a Turbonetics 2 port, you can purchase it at Jeg's
Turbonetics 10402-25 Turbonetics Variable Boost Control Kits |
Do you have a death wish ? I've got on I'll send you!! Seriously good way to blow up a perfectly good engine
Nothing wrong with them.... it is just a adjustable wastegate controller. It can't blow up anything! Now the idiot that doesn't know how they work and or not know when to stop turning the knob on the other hand CAN blow things up! So technically it's the end user that's to blame. It is because these rocket scientists who end up blowing up their motors because they kept turning the knob past the fuel and ignition timing capabilities. Instead of blaming "themselves" They point the finger at a simple device and nick name it ? "Dial-A-Death" . For example, If these genius's would understand that their fuel and timing capabilities are only good to let's say 1 bar, and they have a .7 bar spring in their waste gate, then one could purchase a manual boost controller and add adjustability and be able to fine tune overall boost limit to 1 bar. But since it can boost more the fuel and timing doesn't support it the end user is the Pulitzer prize winner that pushed it beyond the systems ability. Not calling anyone specifically out, just a little venting.
Andial also has a very similar control. I bought an 84 Carrera that had been converted some time ago by Andial and it had a "dial of death". I called Andial in CA and they had one on the shelf. I don't think they had sold one in a while. It's basically a simple air pressure regulator. It was about $58 if I recall. not nearly as expensive and I would have thought. If needed PM me I may still have the part number. I have since gone megasquirt with boost control and efi. It's under the knife, but now in the car thanks to a good friend.
Well it turned out to be a $15 Norgren regulator. I'm going to just order a new one and keep it right under 1 bar. My paper work that came with the car states it has a 1.1 bar waste gate spring.
http://i414.photobucket.com/albums/p...heboost004.jpg http://i414.photobucket.com/albums/p...heboost006.jpg |
My vote is for "dial a death" At least you know where death is....
http://forums.pelicanparts.com/uploa...1340666331.jpg |
Looking Good..
| All times are GMT -8. The time now is 01:36 AM. |
